Question about Starrett D125 Digitape 1Inch x 25 Electronic Tape Measure
Need to purchase battery. Don't know the size for a digitape 125
You may obtain the stock replacement for the tool, designated as a Duracell DL1/3N or as I did, utilize two more commonly available 1.5 V cellls Ag 13/357A but you need to then bend the positive battery contact terminal (the one more inside than outside) so that its point of contact is lowered somewhat..use your leatherman no problem.
Posted on Sep 10, 2010
    New Friend:
Yes use durcell DL1/3N
-OR-
Sanyo (Japan) CR-1/3 - Mn02-Li cell 3volts
Posted on Jun 17, 2015
WHAT IS IGNITION FUSE SIZE ON 125 KYMCO HIPSTER 2005
Battery Fuse : 20A Reserve Fuse :15A Headlight Fuse : 15A Radiator Fan Fuse : 10A All Electric Power Fuse :15A
15 amp
Apr 10, 2015 | 2004 Kymco Hipster 125
How to replace the battery
small door on back side (opposite meter), located at the rear of the tape - press down with thumbs (toward center of case) and back - door pops open - 9v battery underneath
Jul 10, 2014 | Starrett D125 Digitape 1Inch x 25...
The display is always on when I insert the battery- How do mI turn it off?
I installed a larger 3 volt battery and put a micro switch on the positive side.
Nov 19, 2013 | Starrett D125 Digitape 1Inch x 25...
I need to know the torque specifications for a 1983 yamaha yz 125 cylinder
I don't have the factory manual for the 83, but if the bolts are M8 x 1.25, the torque specs are 30NM. The oldest YZ book I have goes to 96, I checked for 96 to present is all the same. That is the standard torque for a fastener that size. Good luck!
Jun 10, 2011 | Yamaha Fuego 50 2T Motorcycles
I need to know what kind of battery is best for my yamaha dt 200 ypvs bike is it 9v battery with 3amp or 5amp
It will probably be 12volt 5Ah. Check with your local dealer for confirmation and exact size.
Feb 25, 2011 | 2006 Yamaha DT 125 X
I can't get the darn thing apart to get at the dead battery. How does it open??
The screw on the side nearest the battery door needs to be removed so the door can slide out, then open to expose the batteries.
Nov 05, 2010 | Starrett D125 Digitape 1Inch x 25...
What battery do i need for aprilia rs 125
The battery is YB9-B YUASA
Alex,
PS-Don't forget to vote me, thanks
Oct 24, 2010 | 1999 Aprilia RS 125 Extrema
Oil bolt has rounded of what size is the bolt??
fit in a helical, and keep in the same bolt, that should solve your problem
Feb 18, 2009 | 2005 Kymco Stryker 125
Need to know the physical size of a battery for a 1996 Cherokee.
Your Jeep Grand Cherokee uses a group 34 type battery. The sizes vary from manufacturer to manufacturer but, the standard size is 10 1/4 " x 6 13/16" x 7 7/8" or 260mm x 173mm x 200mm. Anything close should fit fine. Good luck. Please ask for help any time. Please rate me so I know how I'm doing. Thanks
Dec 30, 2008 | 1996 Jeep Grand Cherokee
Starrett D125 Digitape 1Inch x 25 Electronic Tape Measure Logo
2,197 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
Vernon Taylor
ray gallant
Vuk B
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
