Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
When i go to clean the infuser it will not come out
Have you turned your machine off? You can not remove the infuser if the machine is still turned on, and if you try you will probably damage your machine.
Posted on Aug 01, 2010
Yesterday and today the machine did not come on as normal it said press next + change, nyesterday when I did that it said generic alarm, but then worked, today the generic alarm would not go off. the book...
I had the same problem with the infuser stuck at the top and the triangle light staying lit. I fixed it by unplugging it from the wall. I then removed the side panel and the back panel.
Facing the rear move the sprocket that the motor drives. The best way to start it (if it is stuck) is with a flat screen driver on the right side of the motor and push the sprocket towards the front. Once it starts you can either pull the belt from the other side or push it from the right side. It took 10 minutes to get the infuser to completely come down.
After that I pulled it out and cleaned everything. When I put everything back together the light stayed on and the machine would not respond. I did fix it by turning on the machine, pulled the power plug, and when I plugged it back in the system went through its cycle. Everything is fine now.
Jun 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica rapid cappuccino model EAM 3400.S KEEPS SAYING INSERT THE INFUSER, I HAVE PUT THE INFUSER IN AND IT HAS CLICKED BUT IS STILLS SAYS INSERT THE INFUSER
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
Hi I have a delonghi magnifica expresso machine. We did a cleaning of it and took the infuser apart (the screen off and the curved part with the spring. The machine keeps dumping the grounds into the...
I donot see any error here. Can you reset the spring in the infuser once again. The process of cleaning that you have mentioned is correct or you can follow the steps mentioned bellow :
Please double check whether the cleaning was properly done. Whenever the machine tells you to clean it, which requires you to
- Mobile steam wand while
- opened the door
- the drip tray and trash along
- Dump Truck and clean all the drip tray and waste
- re-assembly
Thanks
Oct 23, 2010 | DeLonghi Coffee Makers & Espresso Machines
'less coffee' error message
The infuser assembly can only be removed with the machine turned off. The infuser needs to be removed and cleaned at least monthly; more often if you use your DeLonghi at lot.
Jun 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk not frothing, internal door not positioned
Make sure that the milk container lid is thoroughly clean and that running hot water flows through the openings freely. Make sure you're using 2% milk. Make sure it's cold 2% milk.
The front door problem may be two loose screws in the back plane that holds the infuser unit. Turn off machine; remove the infuser unit and thoroughly clean. Behind the now removed infuser unit you will see two hex head socket screws; use a hex screwdriver to make sure these haven't come loose. If so, tightened them, but don't overdo it. Now reinsert the infuser and see if the door latching problem has disappeared.
Apr 28, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
DeLonghi Magnifica always asks "Insert Infuser Assembly"
DeLonghi "Insert infuser assembly" error
Easy Fix - Delonghi Coffee machines which have built-in coffee grinders often suffer from a problem that produces an error, "Insert infuser assembly" that appears at random times.
The problem is usually caused by distortion of infuser lifting mechanism limit switch mounting (Orange colored plastic)!
The mounting is very close to the water heater so with heat and pressure from the infuser lifting mechanism the mounting gets bent over time. The switch mounting (Orange colored plastic) gets permanently distorted so the striker arm on the lifting assembly only just presses the micro switch button causing the error message "Insert infuser assembly".
To easily fix the problem on ESAM 5500 machines and should work on other similar machines:-
    1.Unplug the machine and remove the rear cover screws and remove.
    2.Slide out the two side covers.
    3.Remove the grinder lever screw in the top cover coffee bean compartment.
    4.Carefully lift the top cover pushing it slightly back so it does not stick under the front cover (you may have to loosen the 4 front cover screws on the side).
    5.The limit switch is clearly visible on the top (see photos).
    6.Wedge some insulated material (wood, plastic etc, I used bamboo) between the heater assembly and the switch mounting so the switch is in a VERTICAL position. The thickness of the packing is around 3-4mm (see photo).
    7.Re-assemble the machine and enjoy your coffee. JTS
    Alwar, Rajasthan
    India
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
The machinge keeps asking to insert brewing unit but it seems to
The infuser does go in at a slight angle "11:45" ish. Be sure the tabs on the sides of the infuser "pop" back out when it's in place. Try unplugging the machine if all else fails and it will do a self diagnostic. You could also call Delonghi tech support.
Jan 02, 2009 | DeLonghi EAM3400 Espresso Machine
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
531 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
