Question about Dell Ethernet Card Network Adapter
I am using windows XP, when i insert a network connection on the NIC port, the right NIC light blinks yellow instead of Green, repeatedly a message says a new hardware is detected and fails to install. i unistalled the driver installed it again restarted but yet know. of course it refuses to connect to the network
  • simonndunda Jul 28, 2010
    I should have told you am it was working nd now its not working. Does the change of the blinking light from a green light when working to a yellow/orange light when not working have any information i could use , as in what does the yellow light mean. am using dell vostro 1015 and windows xp. its a laptop and i havent changed any hardware it came with.
  • 6,826 Answers
The yellow light means that it's not connected with a compatible driver to the computer or it is not connecting to your network for some reason.
Green, means everything is, ok.
I've encountered this before on some off brand network adapters, and tried other ones, and that was the only way I could make it work...
in an unknown system.
However, since you say that yours worked before... that tells me that you think it should work, again. But, something could have changed in your network.
Are there any other components on your network, like a switch that could have gone bad, or bad wiring?
Posted on Jul 28, 2010
  • Duane Wong
    Duane Wong Jul 28, 2010
    what's the year, make, and model of the network adapters?
  • williamro592 Dec 23, 2010
    i also faced the same issues which you are facing and my friend told me about "ijinni technician" i contacted them at WWW dot ijinni dot COM.any issues. just open the website and you can chat with the experts who are Microsoft certified technicians and will fix the issue itself on the spot or u can call them through Skype or contact and for more visit their website as it is very user friendly website. just click on the chat as the response rate will be very fast from them and they have fixed my issues in no time.
NO NETWORK SETTING SHOW IN LCD PANEL IN BROTHER 8370DN AFTER RESET THE PF KIT 1 MESSAGE.
Hi gurjit: try this..
Reconnect the LAN cable to the hub to verify
that the cable and network connections are good. If possible, try connecting the
machine to a different port on your hub using a different cable. If the connections
are good, the lower LED of the back panel of the machine will be green.
sends me the result.
Nov 26, 2014 | Brother MFC-8370DN Laser Multifunction...
Orange light on instead of green?
If this is on one of the local computer ports and it is blinking it is nothing to worry about according to the manual (http://cache-www.belkin.com/support/dl/p74559-b_f5d7230-4v7_man.pdf, page 11). It is just another normal status color like green but signifies a different network speed/duplex. If you are having issues with network connectivity, please reply with information such as:
1) Is the Modem light on and blinking? 2) are other machines using this router and able to get online? 3) did anything change to the computer plugged into the orange port such as windows updates or new hardware install?
Hope this helps some!
Mar 17, 2011 | Belkin (F5D7230-4) Router (587009)
Hp 2600n printer, flashing yellow light near printer cable
check the IP address on the printer,if u reset ur rooter it will assign a new IP so thats y cant print to it In a future use a host name of the printer so this wont happened again
Feb 23, 2010 | HP Color LaserJet 2600n Printer
After a few minutes conected to the Internet I get an disconnectd running the network trouble sheeter I get the erro mesage that the network cable is unplugged or broken. I replaced the Ethernet cable and...
You might want to open up your device manager on your xp computer and click on network adapters and double click on your nic and copy down the settings under the advanced tab then do the same on the Windows 7 machine and change the values to the same on the Wnds 7 nic adapter.
Jan 28, 2010 | Dell Studio XPS Desktop Computer
Due to the power fluctuation my dell laptop 1501 inspron's lan port or network adapter has been burned so whenever i insert network cable in it. it show the message of network cable unplugged
Most laptop lan ports are onboard so replacement would mean replacement of the entire Motherboard. A very costly option. I suggest buying a USB to NIC adapter from your local PC store and just use that for LAN connections.
(side note: get a good brand, cheap USB to NIC/LAN converters sometimes drop connections randomly so spend a few extra $$$ for a good one)
Apr 20, 2009 | Computers & Internet
Pendrive light not blink error massages.
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply
Apr 06, 2009 | Kensington Electronics - Others
A network cable is unplugged
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | Televison & Video
NIC hardware failure
Maybe your problem is software related. Maybe a virus changed some settings. I would check all the internet settings and the network card settings. I've seen this happen before. In windows xp click Start/Control Panel/Network Connections. Then right click on your local area connection and Click Properties. Slide the bar down to the TCPIP protocol and highlight it, then click Properties. Make sure you are obtaining the IP Address and DSN Server address automatically. Click the Advanced button and make sure DHCP is enabled.
Dec 23, 2008 | HP Pavilion dv1000 Notebook
NIC blinks on then off for longer run lines
You need to update the firmware of the router then hard reset it.
Download the router's firmware at www.linksys.com/download
After updating the firmware, you need to hard reset the router.
Press the reset button at the back of the router for 30 seconds then unplug the power for 30 secs then plug it back in. That should fix it.
Jul 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Error code 10 intel r 82566 nic
The Intel Nic driver did not install correctly. Click on the link below to download the Nic driver. Create a new folder on you're desktop & give it a name. Save the Nic driver into that folder.
Number 4. Under Drivers. LAN: Intel® PRO Network Connections Driver. File name: LAN_allOS_13.0.1_PV_Intel_165622.exe. Run the .exe from within the folder.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2377&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
Re-install the driver. If windows still fails to install correctly than install through device manager. Click on the start button, slide up to & open control panel. Open the System icon. Click the hardware tab, than click on the device manager button. Find the yellow ! point for the nic driver. Right click once on the ! point, than slide up to & left click update driver. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Click the green check mark once & it will go away. Click the Browse button. Another window will open. (Browse for the folder you created on you're desktop).
Open that folder. Left click once on the new yellow folder named LAN_allOS_13.0.1_PV_Intel_165622 so it is high lighted, than click ok. Windows should correctly install the Nic driver. Restart you're system when finished. That's it!
Mike
Jun 14, 2008 | Intel DG965RY Motherboard
Dell Ethernet Card Network Adapter Logo
709 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
