Question about ASUS P6T7 WS Supercomputer Core i7 / Intel X58/ DDR3/ Crossfirex & 3-Way SLI/ A&2GL/ Ceb Motherboard
Hello i have an asus p6t7 sc with 980x cpu and 12gb corsair xms dd3 & evga gtx 480sc card ,wd hdd 600gb reptor & siwfftack water coling sistem. my pc running with win 7 64b the problem is when i am shuting down the pc from windows, in the next start up it say that a new cpu insttld and i need to run the setup agin i did a bios update & i trid to cler cmos but nothing work thanks in advans
5 Suggested Answers
RADICALpcs
  • 15 Answers
SOURCE: I can't use HDD sata on mainboard ASUS P5RD1-VM
boot from CD rom hit F6 when prompted and install sata driver. then you should be good 2 go. If your using a sata cd rom, swap it for a a ide during o/s install then reinstall after o/s install is complete also enable sata in bios 1st as well. I had the same board with a pent D 3.0 that clocked to 4.122 with OCZ ram.
great board but old usb 1 sata 1.5 ..
Posted on Feb 23, 2008
Pterocarpous
  • 202 Answers
SOURCE: Not enough space in Runtime area!!
Hello matt69man
You're doing the right thing by pulling off ALL non-critical devices for booting off your mobo. Take it down to min. RAM, too.
You want the system as bare bones as possible when trouble-shooting this type of issue. Leave only one hard disk drive connected (you'll need the load on the PSU (power supply) or it will balk), min RAM, CPU, CPU fan, keyboard, mouse, monitor. That's it. Disconnect EVERYTHING else.
HERE is Asus-Tek's listing and downloads for your motherboard.
1-2-3 error code sequence is for what BIOS, please? (The error codes ar e unique to the BIOS manufacturer. Ea mfgr has its standard for BIOS audible error codes.)
I downloaded the manual. It looks as though this board is using an AMI BIOS. Is that correct?
Thing is, AMI BIOS codes come in sets of two - not three beeps. So, I haven't been able to match your error codes yet.
Have you brought the BIOS up to date?
HERE is a discussion on an Asus-Tek forum for your motherboard regarding this issue.
I'd recommend you disconnect all non-essential equipment as I described earlier in this post.
Carefully read through how the user on the Asus-Tek forum managed to resolve this issue.
Following that user's recomendations, flash your BIOS to the most current revision.
If you have ANY more questions *at all* on this topic, please, post back here and let us know. We'll be more than happy to continue to assist you until it is resolved or diagnosed.
Please, wait until you have everything you need and you no longer need our assistance b4 assigning a rating.
If I answered your questions and you have no other questions or need of our assistance on this topic...would you kindly take just a moment to close the problem by assigning a FIXYA rating for my "solution"? I would be very grateful for your generosity and show of appreciation.
Thank you once again for using FixYa! Have a beautiful day.
BJ @:)
Posted on Apr 21, 2008
fps353535
  • 99 Answers
SOURCE: bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Posted on Apr 09, 2009
  • 67 Answers
SOURCE: Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Posted on Jan 23, 2010
Asus a8n-e m/b gets power, will not post
Hello from here you can download a manual and drivers:
http://www.asus.com/Motherboards/AMD_Socket_939/A8NE/#download
My guees is that the windows disk is damaged or burned to fast.
Since you not get any picture on screen now the graphic card. maybe malfunctioning try to change that and see what happens.
A ps2 keyboard and mouse must be used.
Because the usb function will not work until the system is fully installed.
A restore disk does not contains a full windows its only for repair
purpose.
Good luck
Nov 02, 2012 | ASUS A8N-E Motherboard
Hey guys. Built a new computer and decided to add a video card instead of using the onboard video. Bought an EVGA Geforce GTX570 SC 1280MB GDDR5. Pretty sweet. But I cant get it to work. Got the...
Hello, Your on-board vga is still active and by default your computer will use this for displaying graphics. You will need to disable it to use your new card or change priority so that it searches for an external display first. To do this restart your computer, go into the bios and turn it off or change priority. Refer to your computer manual for the proper location of this setting.
Please bear in mind that some systems do not give you the option of disabling your on-board vga. I believe this is to allow you to still use your computer should the external vga fail.
Hope this helps, thanks for using FixYa
Aug 31, 2011 | Evga GeForce GTX 570 HD 1280MB GDDR5 SC...
I have the msi gtx 570 twin frozr 2. when i play games like bfbc2 or bulletstorm, my display freezes.sometines even when im not playin.. ill then restart my pc to solve it.. i have the latest drivers nd...
My guess is that your system is getting too hot. That GPU outputs a bunch of heat and so does the rest of your system. You need to bring down those temperatures. Install as many fans as your chassis will allow. 120mm high RPM fans as exhausts say 2000RPM and slightly slower ones for the intake say 1200RPM.
Check the Nvidia website for the latest drivers, check everyday.
Use a program called Hardware Monitor to check the temperatures.
Also install MSI Afterburner, don't change the clock speeds.
Are you sure that the CPU Cooler is making proper contact with the CPU, check this by using the Temperature monitor software.
Update your version of Windows to the latest service pack and security updates.
Check that the PCI-Express cables are making good contact.
Take care!
damnor01
May 31, 2011 | MSI N570GTX Twin Frozr II OC GeForce GTX...
Price to bye
(2) Acer Aspire Predator AG7750-U3222 Intel Core i7 930(2.8GHz) 12GB DDR3 NVIDIA GeForce GTX 470 Acer Aspire Predator AG7750-U3222 Intel Core i7 930(2.8GHz) 12GB DDR3 1.5TB HDD Capacity NVIDIA GeForce GTX 470 Windows 7 Home Premium 64-bit
  • Intel Core i7 930(2.8GHz...
  • 12GB DDR3 1.5TB HDD Capa...
  • DVD Super Multi
  • Type: Gaming
  • Processor: Intel Core i7 930(2.8GHz)
  • Processor Main Features: 64 bit Quad-Core Processor Turbo Boost Technology up to 3.06GHz
  • Memory: 12GB DDR3 1333
  • Model #: AG7750-U3222
  • Item #: N82E16883103296
  • Return Policy: Computer Replacement Only Return Policy
  • Was: $1,999.99
  • Now: $1,899.99
  • Free Shipping
Jan 12, 2011 | Aspire Acer 7520-5071 Notebook
This is my system, -K10N780SLIX3 wifi Mobo -Gtx 260 Evga card -amd phenom II X4 3.4Ghz -6gb ram -1tb WD sata HDD -1000watt power supply. And I can not get a display anymore but it starts up fine, no beep...
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
Apr 18, 2017 | Asrock Computers & Internet
Freeze up system after booting
  • check the CPU fans for dust,
  • run a HDregenation program on the HDD
Nov 09, 2009 | ASUS M2N32 WS Professional nForce 590 SLI...
Hard time getting new build to boot...
sounds to me like you either have a conflict of hardware or your os windows xp wasn't meant for your hardware some manufacturers design there products now to be vista only so read you manuals and make sure of that then try reloading xp but with bare essntials to run a pc that is
Mar 15, 2009 | Computers & Internet
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Looking for love. Some one please Help
The problem is your cpu, you need to upgrade to am2+
http://www.asus.com/products.aspx?modelmenu=2&model=1751&l1=3&l2=149&l3=591&l4=0
Quote memory part of page
"DDR2 1066 is supported by AM2+ CPU only "
Jul 24, 2008 | Computers & Internet
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
ASUS P6T7 WS Supercomputer Core i7 / Intel X58/ DDR3/ Crossfirex & 3-Way SLI/ A&2GL/ Ceb Motherboard Logo
125 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
