Question about Whirlpool Refrigerators
I have a Whirlpool fridge WBM46LW top freezer that the alarms beeps, light flashes and motor cuts in & out when door opens or sometimes after a few seconds with door open.
  • deechap
    deechap Jan 28, 2013
    I have the exact same problem, same model fridge. Has anyone got an answer yet?
  • Anonymous Mar 12, 2014
    the model number is WBM46LW I want to know what size this is
    New Friend:
  • 32 Answers
Hello All.
I would like to add my findings.
My fridge of 11 years started behaving exactly as the OP described. I tried all the suggestions regarding holding buttons, power off etc to no avail.
I even found an online manual here
https://www.yumpu.com/en/document/view/18647891/whirlpool-uk-refrigerator-models-wbm35lw-wbm35ls-/5
But that did not address the problem at all.
So I went back to someones suggestion about the Potency Module.
I pulled the fridge out and unscrewed the cover at the bottom left to get access to the Potency module.(Red plastic box)
Without even pulling it open I could smell the burnt electronics.
I opened up the case and found a scorch mark next to the big capacitor on the circuit board.
So far, so good.
Given that a new fridge of the same size/style is about $1300 I pursued the spare part.
I then tracked down a supplier in Melbourne with a new board/module for $148.50. P# WPP326020913
Plugged in the new board in and fired up the fridge and its working just like new.
So I am happy now that a perfectly good fridge is up and working again.
Posted on Nov 18, 2015
Clwarren - my fridge has also started doing this... did you find a solution to this issue? Paul pauladamwheeler@gmaill.com
Posted on Sep 24, 2011
  • Simon Wilmann
    Simon Wilmann Nov 24, 2013
    mine is doing the same for both the fridge and freezer. did you work it out? ping me if you did whirlpool@v6gemini.com
How do I fix the continuous beeping coming from my refrigerator?
LG Fridge Door Alarm ' Chris Inch
www.chrisinch.com/blog/articles/show/lg-fridge-door-alarm/
Aug 30, 2006 - It's just too bad I can't live with beeping noises going off every 30 seconds. .... took them a long time and they scratched the paint) the fridge beganbeeping ..... I opened the fridge door to let the alarm sound and then located the alarm..... I can't tell you how many times I've "snapped" since hearing this thing.
FIXED Frigidaire Professional Constant Beeping - ApplianceBlog
www.applianceblog.com/.../17546-Frigidaire-Professional-Constant-Bee...
Jan 15, 2010 - 10 posts - ‎3 authors
The refrigerator is not refrigerating and I don't here the fan go on or ... the water comes out from the water dispenser and so does the ice. ... Thank You so much! ... The unit is two years old from time of purchase. ... Then to install it you remove the #81 screws here: 11-Controls parts .... All times are GMT -6.
Fisher & Paykel fridge in alarm - Kitchen - Home - Whirlpool
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolJan 24, 2010 - I push the selector button to mute the alarm and then it may not do it again ... I can determine the fault code through the number of beeps/flashes? ... myfridge started beeping every 6 hours abut a week ago. ... posted 2012-Aug-7, 3:17 pm.... If so, defrost the coils behind freezer, you can use a hair dryer to ...
Feb 03, 2016 | Refrigerators
Hi, I have fisher and paykel E522BLX bottom freezer fridge. It is making beeping sound sometimes when I open the door. It also has green light flashing on the control panel all the time. Both fridge and...
beeping when door is open is one of its features the flashing light means someone has tried to set something and not completed the selection just try pushing one of the buttonstill it stops
Jan 29, 2018 | Fisher and Paykel E522BLX Bottom Freezer...
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
Whirlpool fridge freezer ARC 4030?
Look to have the control module repaired / replaced.
Hope this helps
Dec 02, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Whirlpool door alarm
Is just a little switch on inside of the door hinge covers if you short it out the alarms will never go off again.
Jun 28, 2009 | Whirlpool ARC4030 Stainless Steel Top...
Fridge turns on and off and beeps
You need a tech to check the problem, it seems to be some kind of electrical short or, if the fridge has an electronic control module, it may be the source of the proble.
Jul 20, 2008 | Whirlpool ET0WSRXML Top Freezer...
Refrigerators Logo
1,354 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
