I have a strashoff portable air conditioner and it started to work fine then a day later this e1 came up and cannot seem to get it to work
  • 86 Answers
SOURCE: Code E1 on my Samsung AW1204B Air Conditioner
read manual properly.
may be remote problem
make off airconditioner then after 5 minitue on again
Posted on Mar 17, 2008
SOURCE: reset air conditioner
This did it for me! Same procedure but its described a little more thoroughly here...
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Posted on Jul 21, 2008
6ylucy
  • 742 Answers
SOURCE: boston innovative products MOB 10KDCHR portable
i found the user manual for it at:
manualfox.com/link/bostoninnovative.htm
Posted on Feb 13, 2010
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Window_Room_Air_Conditioners
Posted on Jul 06, 2010
SOURCE: carrier holiday portable air conditioner manual
Mine has a model number of PCA061D.
If you remove the water capture reservoir, there is a sticker that has the model number.
Posted on Sep 29, 2010
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Error code e1 starway air conditiiner
one day at home by mistek my top level and bottom level switch was off and i start me air condinion after that i get error E1
how to fix this error
thanks
jatin
Oct 13, 2013 | Sharp AF-S85FX Wall/Window Air Conditioner
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
Air conditioner has to be reset --E1
If your a/c unit is portable,and E1 code most always is "air filter cleaning time" or" water level to high ".
To reset air filter interval turn unit off at power switch then unplug.Hold power switch down while plugging in....unit will go through a short self check then beep.Release power button after beep.Unit should now be reset.
To reset water level....just drain some.....not all.
Most portables use water for increase cooling......so leave some in.
Jul 27, 2008 | Sharp AF-S100FX Air Conditioner
Portable a/c water problems
either the area you are cooling is extremely humid or your a/c is freezing up, shutting off  and melting alot of ice before it comes back on.
Sep 02, 2007 | Maytag Portable Air Conditioner M6P09S2B
Heating & Cooling Logo
431 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
