Dear Sir/MAdam Our Rinnai Gas Heater, Model 404, works ok, but when put high it shout downs by makine a constant wishle noise. After a number of shutt down and turn on, it is ok provided to leave it at low low level, which does not heat up the entire villa. What is the problem and how can it be fixed? I am a handy man, so can I fix it or take it to a service centre. Where is the nearest service centre for me. I live in Ryde of Sydney (Post Code 2114). Regards Assad
    New Friend:
Normally the heater will let out a screeching noise when it hasn't ignited properly thats why i think its the switch that may create the noise - very annoying
Posted on Jul 01, 2013
It sounds like you have a air noise, this is created by high velocity air. You may have a leak or the duct size is to small for the volume of air passing through it.
Regards
Shane
Posted on Apr 24, 2008
Extremely annoying humming sound coming from our rinnai RCE-318H gas heater. sounds like a bearing or wheel spinning noise. please help?
The humming you hear is from the gas pressure or lack there of. Check the inline gas shut off valve, to make sure it's fully open. If that checks out OK, turn the unit OFF completely and wait five minutes, before turning everything back ON and relighting the heater. If the noise is still there, contact your Rinnai dealer for a service call.
I hope this helped you, Arthur. Thanks for choosing FixYa. Cheers!
Aug 27, 2011 | Rinnai Heating & Cooling
I have a Rinnai RCE 329H gas heater and no instruction manual of how to attach it to the gas pipe. Please could you advice. Thank you.
debbaruah - I have searched every Rinnai data base, on 3 continents, at my disposal and have not been able to locate a current Rinnia gas heater with the model number RCE329H. Are you certain that is the correct model number?
Please advise. Thanks.
Jun 09, 2011 | Rinnai Heating & Cooling
I am having problems with turning my gas heater ( Rinnai Convector 404) on and also a high pitched ringing sound, we were given the heater a cpl weeks ago and managed to use it no probs for a few nights...
This noise you hear may be a result of a gas pressure problem to the heater. Generally, it's caused by low pressure. Low, meaning below the the standard required by the manufacturer for this heater. The gas regulator on the heater may be stuck in a partially open position or the line that furnishing the gas to the heater is to small in diameter. Also, check the gas line shut off vale, to make sure it's fully open.
Hope this helped you troubleshoot and solve the problem.
Jun 04, 2011 | Heating & Cooling
Have a Rinnai convector 404 that has a ear piercing whistle to it as soon as you turn it on, have had a look with covers off and it seems like the noise is coming from where the gas comes into the heater.
Most likely it is a problem with the gas pressure or the air adjustment. You will need a Manometer to be able to check it and adjust it so I would recommend you call your local gas technician. If you have a shut-off on the unit, you can test this by throttling down the valve till the whistle diminishes however this is not a fix, just a diagnosis.
Apr 25, 2011 | Heating & Cooling
When the temp drops below 10degrees our Rinnai
rinnai has a technical bulletin out on this condition #28. It instructs the technician to adjust the gas pressure. You can get a copy of this bulletin by contacting rinnai at 800-621-9419 (US). or at rinnai.us
Feb 02, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
Jun 01, 2009 | Rinnai Vent Free Gas Heater/
Change Natural Gas Model of rinnai Heater to LP model
You can change the dip switches, but you may also need to work on the gas valve
Nov 12, 2008 | Hotpoint RGB528 Gas Kitchen Range
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Jun 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
