Question about Zebra Z4Mplus Label Printer
The printer gives a message that says ribbon out. It is Direct Thermal and no ribbon is required
    Problem Solver:
  • 15 Answers
Check your program settings, it might be configured to print as a thermal transfer
Posted on Feb 18, 2011
I HAV A DATAMAX I-CLASS PRINTER IT IS SAYING THAT I HAVE A RIBBON FAULT AND THE PRINTER IS THERMAL
Thermal can mean "Direct Thermal" (no ribbon) or "Thermal Transfer" (with ribbon). If you want to print using Direct Thermal labels you need to select Direct Thermal from Media Settings in the Menu accessed from the Control Panel on the front of the printer. Otherwise, the printer sensors will look for a ribbon that is not there, and you will see an error message.
Feb 16, 2015 | Datamax I-4208 Thermal Label Printer
We can't get rid of the message, "ribbon out" and
Try going into the settings and setting to direct thermal not thermal transfer.
Jan 07, 2011 | Zebra 140XiIII Plus Thermal Label Printer
PRINTER IS NOT PRINTING rUNS NORMASL JUST NOT PRINTING
Check the settings. If the printer is set for thermal DIRECT and you have thermal transfer labels, this will be the result. Thermal direct requires thermal sensitive labels. Thermal transfer requires a ribbon.
Hope this helps,
Dan
May 24, 2010 | Zebra LP 2844 Thermal Printer
I have a Z140XiIII that used to have a ribbon and thermal transfer stock. we changed the stock to not require a ribbon, so we removed the ribbon and set the menu to Thermal direct. labels print OK but the...
If the printer is flashing "Ribbon in" then it sounds like the printer setting to Thermal Direct is being changed back to Thermal Trans. Verify this after sending a format. This is very common because the printer is bring over-ridden by the software and/or printer driver when you send a format.
Look for a setting in the software / driver for direct thermal and make the change there.
Hope that helps.
Apr 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
No print with ribbon
Did you put a ribbon in your printer? The zebra does both direct thermal and thermal transfer, but you need a ribbon to get it to print AND have to change the settings to let the printer know that it needs to use the ribbon instead of direct thermal.
Jan 08, 2009 | Zebra Z4M Printer
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
Z600 wont print, ribbon error
in the switched at the front of the printer you can configure it to direct thermal mode.. or if you are using printer driver please configure it also to direct thermal mode..
Jul 08, 2008 | Zebra Stripe S600 Thermal Label Printer
How to say to the priter we don´t use ribbon
If you are printing in direct thermal mode (without a ribbon):
· Check your software settings and make sure that the print type is 'direct thermal'. If your software package requires the use of a Windows driver, also make sure that the driver is set for direct thermal printing.
If you are printing in thermal transfer mode (with a ribbon):
· Check your software settings and make sure that the print type is 'thermal transfer'. If your software package requires the use of a Windows driver, also make sure that the driver is set for thermal
transfer printing.
Check to see if there is any dirt on the ribbon spindle gears or on the ribbon motors. For the latter
you will need to remove the electronics cover. If there is dirt in either of these areas, try vacuuming around the motors and/or the spindles to remove as much of the dirt as possible.
Mar 17, 2008 | Toshiba TEC B-472 Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
185 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
