Question about Canon PowerShot G9 Digital Camera
CANON G9 WONT TURN ON BATTERY FULLY CHARGED - Canon PowerShot G9 Digital Camera
  • 7 Answers
This camera has a common problem where some internal screws get loose and it creates a short and no power. The site that services these is: www.camerasandparts.com Since they only do the powershot models they are really experienced with these. It costs $89 for everything and all of the service for the camera included. They're great for help with these and they automatically do the no power correction on the G9's they service. Hope that is helpful for you, I wish you the best with it.
Posted on Dec 12, 2010
  • 5 Answers
More than likely it has a short which is usually why you would get no power. You can get that problem fixed at: www.camerasandparts.com They are excellent if you need to have a canon camera worked on.
Posted on Oct 25, 2011
  • 36 Answers
There are two screws in the top cover that fall out and short out the DC/DC board. This board needs to be replaced and then all will be well. Usually costs between $100-$125.
Wes
Posted on Sep 10, 2010
happyjulie
  • 5 Answers
SOURCE: Canon g9 won't turn on...battery is fully charged.
These cameras short out inside from a loose screw. The place that a lot of people go for help with this problem is www.camerasandparts.com They just work on the Canon powershot models and they are wonderful for service, about half the cost of most place for about twice the service. The nice thing about them is they do a fix inside the camera so the screw problem won't happen again. They're the place for help with these, lots of luck with it.
Julie
Posted on Aug 24, 2011
SOURCE: my Cannon G9 digital
My g9 was working fine and then..... I went to take a picture, powered up and that was it. Can't take a picture, lens stays out, can't turn it off, it will do nothing at all. Battery is fully charged. HELP!
dw
Posted on Oct 06, 2008
BillB-SA
  • 2761 Answers
SOURCE: battery fully charged. but canon powershot sd600
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
Ranglo
  • 1194 Answers
SOURCE: canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
  • Direction of your battery might be wrong, Check out and put it again.
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Check whether Memory Card/Battery Cover is properly closed.
  • Load new or fully charged battery.
  • Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Posted on Mar 05, 2010
amygooseanda
  • 5 Answers
SOURCE: Canon G9 blinking green indicator light
Go to this site and try emailing them: www.camerasandparts.com They just service the Canon Powershot cameras and they are wonderful for help with these. They do excellent work and are about half the price of Canon. Hope that helps, best of luck with the problem.
Posted on Dec 15, 2011
My canon powershot g9 will not turn on
Your camera probably developed a common short that the G9's sometimes get. You'll need to have it serviced and if you go to this site: www.CamerasAndParts.com they service the Canon Powershots exclusively and they are excellent on these models. It's $89 with them and you get parts, labor, servicing for the camera, and most important they perform the no power correction on the camera too. Shipping is included on the way back with them too. For $89 they're tough to beat. They are experts on these models and the only place I'd go for a Canon Powershot. Good luck with yours.
Nov 30, 2011 | Canon PowerShot G9 Digital Camera
Camera won't turn on. Flashes red and orange lights by the view finder and blue at the s button. Battery is fully charged. Just use the camera the other day and it worked fine
The Canon G9 has a design defect, two screws fall out inside the camera and short out the fuse. If you've never had it fixed for no power before this is most likely what has happened to your camera.
Do a Google search for "canon g9 no power repair" and you will see a full repair service including return shipping of your camera for just $85.
Hope this helps!
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Apr 26, 2011 | Canon PowerShot G9 Digital Camera
My Powershot G 9 will not turn on. I charged the battery when I noticed it wasn't on. The green light says it is fully charged. This just happened today
You most likely got a short in the camera. A great place if you need service for this model is www.camerasandparts.com All they deal with is service for the powershot models and they are not much at all pricewise. They have the G9 no power repair with the service on their site. Hopefully that will help, they are excellent for service on these particular cameras.
Nov 25, 2010 | Canon PowerShot G9 Digital Camera
Canon g9 won't turn on...battery is fully charged....mysteriously stopped working.
Julie
Apr 11, 2010 | Canon PowerShot G9 Digital Camera
Canon g9 won't power up
is your battery fully charged? if not, thats probably your problem.
Oct 10, 2009 | Canon PowerShot G9 Digital Camera
My Canon G9 won't turn on as well!! HELP PLEASE!!
Sounds like you have the short in the camera that a lot of people get on this model. A terrific place for help with this problem is: www.camerasandparts.com It runs $89 all in with the servicing for the camera included. They just work on the Powershots exclusively. They're very familiar with this no power problem on the G9. An excellent place if you need service for a Powershot.
Aug 25, 2009 | Canon PowerShot G9 Digital Camera
Camera will not turn on with a fully charged battery
From what I read on the canon site they recommend that you get new battery and get good ones and clean contacts
Feb 03, 2009 | Canon PowerShot G9 Digital Camera
My Cannon G9 digital camera wont power up even though I have a fully charged battery?
This is usually from a loose screw inside the camera, a screw inside the camera can come loose and cause a short which is very common on the G9. If you go to: www.camerasandparts.com all they deal with is service for the Canon Powershots. They're great if you need a hand with one of these and they automatically do the no power correction on the G7's and the G9's they service which is nice. They are about the least expensive out there at $89 and they include the service and the shipping back. The best part, they do excellent work which is a must for me. Hope that helps you some.
Aug 17, 2008 | Canon PowerShot G9 Digital Camera
Canon PowerShot G9 Digital Camera Logo
284 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
