My computer no audio device - Computers & Internet
  • 808 Answers
Update ur audio driver
Posted on Jul 28, 2010
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
My audiodriver not working
The essential thing to diagnose with any computer fault is to think back to when the computer was working normally and then list any hardware, software or settings changes between that time and when the fault first appeared.
Audio problems are often simple settings problems. Before you try anything else think if you have connected any new device or installed or used any new software on the computer that is Audio-related (such as a cellphone, an MP3/MP4/MP5 player, a bluetooth device, a microphone, a Voice Over Internet Protocol [VOIP] Headset or multiplexing device, a dial-up modem or dial-up modem based transaction or stock keeping or postal franking device, a multimedia player, a speech recognition program, media playing software, fax/phone software, etc., etc. Any of these sorts of devices or software are capable of changing a computer's default audio settings.
Reset the audio to the correct default device - start -> control panel -> sounds speech and audio devices/hardware and sounds -> audio -> select main audio on-board chip or sound card from the Playback Device drop down menu or the panel of different device options -> apply -> OK -> restart computer.
Often this is all that needs to be done to restore audio that has been disabled by settings changes.
f not then turn your mind to a possible Audio/sound Driver conflict, corruption or deletion.
Uninstall all components of the installed Audio/Sound Driver from Add or Remove Programs/ Uninstall a Program or its equivalent in your Operating System - > restart the computer -> reinstall the Audio/Sound Driver from the Drivers and Utilities Installation Disc or download, save (so as to create and keep on the computer the Sound/Audio Driver Setup Files in case of future Sound/Audio Driver problems) and install it from the Support and Download pages of the Acer website -> restart the computer.
The Sound Audio Driver for this model can be downloaded from :
http://www.official-drivers.com/installer/?seed=acer&gclid=CPj_o9nqwqwCFQIf4QodnBReqg
Nov 19, 2011 | Acer Aspire One PC Notebook
No sound on acer aspire m1610
Verify the speakers are plugged in and turned on and volume is turned up.Also check the volume control on the computer and make sure it is not muted.Go into Device manager and make sure there are no problems (yellow ! or ? and red x) If there are download and install the audio device driver to fix the issue. If you dont know which device you have you can download SIW or aida64 to help identify your audio device.
AUDIO DEVICE: integrated Realtek ALC888S high-definition audioDRIVER DOWNLOAD: http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=342
Nov 10, 2011 | Acer Aspire Computers & Internet
Audio output device
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
Jul 20, 2011 | Microsoft Windows Vista Home Premium with...
How will I know the version of my audio on my asus eepc?
If you really want to know what is the version of your audio device, here is some steps.
  1. If you have the Driver CD of your PC, Install the drivers for your audio and then do this steps.
  • Right click My Computer and then at the menu that will appear, choose Manage.
  • On the Computer Management window that will appear,click on the Device Manager ( it is located at the left side underneath the Performance Logs and Alerts.)
  • Now, on the right side of the window will appear the list of devices installed in your computer, Look for the Sound, Video and Game Controllers and click the (+) sign beside it to expand the device.
  • Once the device expanded, Look for your Audio Device. Like the one in the picture below, mine is Via High Definition Audio. heifentrixx_10.jpg
  • Right click on that device and choose Properties.
  • Now on your Audio Device Properties, click on the Driver tab located at the top.
  • After clicking the Driver tab you will see there the Driver Version of your Audio Device. That is one your looking for.
If you dont have the Driver CD try using this software. DOWNLOAD ME
  • Download, Extract and Install the Software.
  • Run the Software and then at the left side you will see the Devices in your computer, click on Multimedia.
  • After clicking Multimedia, you will see all the audio devices installed in your computer, click on Audio.
  • Now after clicking Audio, you will see the device version of your Audio Device thats the one your looking for.
Goodluck. Hope my solution will help. Thank you for using Fixya!
Jul 07, 2011 | Computers & Internet
No sound got eroor code 1b63:061b , 0f1b , 151b, 101b
This error code is usually generated by a Dell Computer. I suggest that you perform an extended test by pressing the F12 Key at the startup of the Computer.
Furthermore, you may go to the Device Manager and check the status of the audio devices which are listed under the "sound, video, and game controllers" category.
I suggest that you try uninstalling and reinstalling the Audio devices from the device manager.
In order to uninstall the audio devices from the Device Manager, please right click on the device and then click Uninstall. It's required to restart the Computer after uninstalling a device. Once the Computer is restarted, reinstall the appropriate Audio driver. You can download the audio driver from the support site of your Computer manufacturer.
Jun 22, 2010 | Dell (8H390) Sound Card
How to install audio device in window xp?
Did you mean install audio device driver? It depends on the manufacturer of your pc. Go to their website, and usually they have available free downloadable audio drivers for the corresponding Operating systems used by their customers.
May 26, 2010 | Computers & Internet
No audio device
The "No Audio Device Error" message is usually displayed by your computer when it does not detect any properly working audio device attached to it. You will not hear any sound from your computer when this message appears. Only the internal speaker of the computer can provide you bleeping sounds.
When this message appears on your screen, you will need to first check your computer's BIOS and ensure that the audio is set to "auto" mode. You should also check if you have installed the correct drivers needed by the audio device attached to your computer in order for it to work properly.
Audio Device Drivers The most frequent cause of this problem is an incorrect audio device driver that has been installed by the user. In order to double check if your driver matches your device, refer to the user's manual that came with it to look for its type and specifications. The audio device driver for an onboard device should be provided along with the chipset drivers in the CD that accompanies the motherboard.
Use the Device Manager You can use the device manager to ascertain if the audio device drivers are installed properly. To go to the device manager, right click on the My Computer icon, then click Properties, click on the Hardware tab and then Device Manager. If any device is marked with a yellow question mark, it is an indication that the required drivers are missing. It should be instantly clear if the audio device is truant.
Loose Connections on the Motherboard You can open your computer and directly look at the information written on the audio device itself. While doing this, make it a point to check all connections by ensuring that everything is properly plugged in its correct place. Sometimes, this error is also caused by loose connections and a sound card that has been improperly attached to the PC.
You can download the latest updated drivers from the manufacturer's website, either from your own computer or another. If you have used another computer, you can use a data storage device to bring the drivers to your machine and execute the software installer from there. Ensure that the driver you have downloaded is compatible with the operating system installed on your machine.
Is Your Audio Device Defective? If problems with your audio device still persist, you can opt to test the audio device on a different machine just to see if it's in good working condition. If it still doesn't work on a different machine, you have a defective audio device. You will need to get it replaced if it is under warranty or purchase a brand new one. Remember that you should buy the audio device that is compatible with your motherboard. In addition, don't forget to ask for the updated software drivers of the audio device
May 18, 2010 | Computers & Internet
My computer is saying no audio device just installed new Windows XP to my computer yesterday. And then there's no sound from my computer. I clicked the sound and audio devices in the control panel and it's...
if it is a laptop you can get the drivers from the manufacturer's website easy. If it is a home made desktop you can download a driver identification tool or simply open your computer and read the model number off the motherboard. Some computers display this model when you first turn it on. In either case the components or motherboard driver manufacture has the download available on their support site.
Nov 08, 2009 | Sakar Adrenaline Computer Speakers
AUDIO DEVICE
go to properties of my computer then choose hardware, then choose device manager, here u will find list of hardwares over here u will find audio device with a wuestion mark, right click this and choose update driver...!!
thankyou
Feb 16, 2008 | Logitech X-540 Computer Speakers
Computers & Internet Logo
12 people viewed this question
Alun Cox
David Payne
David Payne
