Hi i have replaced my cartridges and one of them with Yellow ink is not been recognised bij my epson stylus sx100. I have placed a yellow cartridge T0714. I have followed everything like it should. Can you help me? Thanks
  • 415 Answers
If the yellow is original epson ink then I would recommend you take it back as it may have a faulty chip, else try cleaning the printer and try again
Posted on Jul 28, 2010
SX200 WILL NOT RECOGNISE NON STD INKS
Check your update settings in the printer software. Turn off any automatic updates from Epson. To get updates, put some old Epson cartridges, good or bad, in while you update. Epson will log on to your printer and kill your non-Epson cartridges during auto updates.
Apr 09, 2015 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus shows out of ink with full cartridge
it is the problem your printer head change it and then solve
Jul 13, 2009 | Office Equipment & Supplies
Printer doesn't recognise new ink cartridge
Please don't be offended if I ask that you carefully check whether you have removed all packaging
of the cartridge, including the ink seals on the heads of the cartridges you have supplied. Believe me,
this is a VERY common problem, and given your elimination by purchase of two additional cartridges
is more likely your problem than defective cartridges, assuming that all such yellow cartridges are not
DOA at FOB.
Apr 07, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Don't know how to move the cartridges to replace the ink.
Please follow the instructions below to ensure correct installation:
  1. Lower the printer's output tray and open the top cover.
  2. Connect the power cable to the printer.
And switch on the printer.
The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    Do not touch the green chip
    on the side of the cartridge. This can damage the ink cartridge.
    Remove the yellow tape from the bottom of the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    Cartridge stuck
    hi follow these instructions http://www.fixya.com/user-guide/p342978,m2965,gm23/Epson-Stylus-C86-InkJet-Printer.aspx + http://www.fixya.com/user-guide/p342978,m2965,gm33/Epson-Stylus-C86-InkJet-Printer.aspx good luck
    Apr 02, 2006 | Epson Stylus C86 InkJet Printer
    287 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
