Question about Microsoft Zune 2nd Generation Digital Media Player
Frozen screen Earlier today I turn on my zune and all the pops up is the Zune logo, and what seems to be a loading bar. I've left it be for over an hour and the bar has yet to move. it won't register on my computer too. Help?
  • 10 more comments
  • Anonymous Oct 08, 2008
    u can hear it tryin to run but the screen is black
  • Anonymous Oct 16, 2008
    It's not even funny anymore...
  • Tomarva Oct 29, 2008
    My zune Mp3 player has been frozen for about 2 days on the playlist, cant hear or play any thing please help.
  • Anonymous Nov 05, 2008
    Between my sons and I we have 3 different zunes and 3 different problems. Garbage! DO NOT BUY ONE!
  • Kristine17 Dec 31, 2008
    My brother's zune is doing the exact same thing...mine has been going slower for the last few days. Hopefully mine doesn't do that either :(
  • Anonymous Dec 31, 2008
    i have this same issue as of tonight. i was sitting at my pc listening to my music when it just stopped playing and seemed to reboot on its own, never getting past the logo screen. i've tried the reset trick and it won't budge.
  • zh582070 Dec 31, 2008
    Same here. Turned off by itself, and when try to turn it on, won't pass the logo screen and the bar...
    Mine froze this morning when i tried to turn it on. It's just frozen on the loading screen...what to do...
  • toddb532 Dec 31, 2008
    same problem. zune logo, status bar filled. wont respond to PC hook up or docking station. None of the resets work.......
    BUG???
  • Nova425 Dec 31, 2008
    I have this same issue with my 30 gb. It's frozen on the main logo screen with the loading bar filled. I've tried to drain the battery and restart the zune by charging it. Nothing is helping - I believe this is a real big firmware problem (new year bugs).
  • bikerscout15 Dec 31, 2008
    I have the same Issue I woke up this morning with my zune frozen on the loading screen It died on the way to work I hooked it up to my PC to charge its turned back on but still stuck on the loading screen Thanks M$
    Same happend to me this morning it froze on the loading screen if ne one knows how to fix this please let me know
Not really a solution... but this explains the problem, to all those who've had it on December 31.
http://gizmodo.com/5121311/reports-30gb-zunes-failing-everywhere-all-at-once
Posted on Dec 31, 2008
MP 4 SONGS
Posted on Jun 23, 2008
Zune does nothing! Screen says Zune with loading logo but...
Let it on and completely drain the power, then try it. Make sure your lock key is not locked either. (at the top of Zune Device)
Jul 15, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
120GB Zune wont turn on
Please try to hold Back, Center and Left at the same time to restore the zune,
Jun 02, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Frozen screen
Got it working again. Disassemble and disconnect the batery for about 10 seconds. This worked to resent mine and it's working again. Not sure if it's permanent, but working for now.
Disassembly instructions:
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Frozen zune
try reformatting it then reinstall the zune formware that might fix the issue.
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
Zune screen froze
http://forums.zune.net/403986/ShowPost.aspx check the zune forums for any updates. microsoft is looking for a solution. this happened to every 30g owner 12am/2am
30 gig zune frozen on "ZUne screen"
Theres a note on the zune website about this issue today... Looks like its microsofts fault! At least I feel better knowing I didn't break my zune!
Dec 31, 2008 | Microsoft Zune 2nd Generation Digital...
Microsoft Zune 2nd Generation Digital Media Player Logo
104 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
