Question about E-Machines eMachines Desktop PC
T5086 pc with lcd emachine monitor suddenly gets too bright after startup and stays that way
  • 808 Answers
Its may be ur VGA problem or might be lcd fault
Posted on Jul 28, 2010
Emachines el120006w momitor quits displaying shortly after startup or won't even display after startup
Try another monitor, reseat ALL monitor cables .If you have a Graphics Card, shut down computer, unplug and reseat Graphics Card.
Dec 15, 2012 | eMachines EL1200 PC Desktop
My emachines lcd flatscreen monitor is flashing
No. You have a bad capacitor/s on the monitor's power board suggest replacing with new ones. Here is what a blown capacitor looks like. If you are comfortable fixing this yourself, good, you will save money this way. If it isn't a bad cap then it is probably a bad IC.
65daaa1.jpeg Notice the two round things side by side. The one on the left is blown.
l l
BAD
Jul 05, 2009 | E-Machines eMachines Desktop PC
Monitor works in dos starup, but fails in Vista startup mode.
Sounds like windows resolution or refresh rate is too high for the 15" monitor. Try starting in safe mode and setting the resolution below 1024 X 768 and refresh at 60. Restart.
Mike
Feb 16, 2009 | E-Machines eMachines Monitor E15T4
Keyboard and Mouse stopped working
Are the Mouse and keyboard Wireless??
Jan 17, 2009 | E-Machines eMachines Desktop PC
HP Monitor comes on with bright white screen since changing PC
Try using a different wall outlet to plug in your monitor. Believe it or not this actually may help.
What ever breakers you are talking about to get the monitor going doesn't really have anything to do with the drivers. Monitors are "plug and play" meaning the drivers are installed for you when you plug it in. It"s possible you don't have the connections on securely or maybe one of the pins are bent. Does it say "restore active desktop" anywhere on your screen?
Also possible the power supply isn't strong enough for your lcd.
Dec 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Brightness box
I suggest you to track faulty component at logic board.
Apr 19, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Color on monitor
First, have you degaussed the unit to stop any magnetic interference?
Do you use software to change monitor settings or do you use the on screen display menu on the monitor?
Most lcd's have a button for menu on the lcd. This can be used to adjust color, contrast, brightness, degauss, as well as screen position and size.
Mar 06, 2008 | E-Machines eMachines Monitor E15T4
T5082 keeps abruptly shutting down
Sounds like it may be overheating. If you get warning beeps on startup that sounds high, low, high low, it is overheating. you should inspect and clean the fan on the processor with a vacuum or compressed air ans also clean the power supply area with a vacuum to clear all the dust out. Inspect and wipe any other dust away from the motherboard and card inside. After restarting, it still goes off, check that the fan is running during startup. If not, the fan needs to be replaced at a nominal cost. This is an easy fix. If this all fails, let me know so we can troubleshoot everything together.
Nov 19, 2007 | E-Machines eMachines Desktop PC
White startup screen
try this test: put pc into hibernate mode and allow full cycle. if monitor ceases problem, then original problem may be with pc's video output only.
Jun 08, 2007 | Hyundai ImageQuest L17T 17" LCD Monitor
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
