Question about ViewSonic Computers & Internet
Lime green screen - is it repairable? - ViewSonic Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
If you are using a CRT monitor then go to a local TV Mechanic and he will be able to solve this problem for you.
Posted on Jul 28, 2010
Screen suddenly turned lime green. Now when turned on turns lime green then goes to red color
sounds like you're using component cables for or HD, check your cables and make sure they're plugged in with the right color code and make sure they're tight. If you can't find anything wrong try replacing your HD cable whether it's HDMI or component.
Jun 25, 2011 | Sony KDS-60A2020 60" HDTV
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
When watching a movie, on the bottom left of the screen is discolored. like on the blue screen, its lime green
This problem only happens when there is something magnetic in by the tv where the screen is lime green. Good luck!!!! hope this little bit of info helps
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
How can i make my lime green ipod nano work again?
It probably needs to be reset. Just hold down the "Menu" button and the middle button for about 7-8 seconds.
Hope this helps!
Aug 24, 2009 | Apple iPod nano MP3 Player
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Screen is green!
Something with the picture tube drive circuit or the picture tube its self has a problem AS I have stated before MANY times in the past, If your not a trained technician, then this is not a repair you should attempt to repair or experiment with for a repair. Find a reliable tech to assist you with this repair as theres too much HIgh Voltage in these set6s for you to be playing with it . Good Luck
Aug 09, 2006 | RCA 14F400T 14" TV
Computers & Internet Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
