Question about Cameras
I Have Sansui DVR 515r Recorder. Its TV Tuner is burned and I want New One Will You help me
MY DVD recorder is dead. It is learnt that its board is not working. where can I get it??
Posted on Apr 07, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 185 Answers
Sdf
Posted on Jul 28, 2010
My Pioneer DVR-320-S tuner did not pick up the free-to air HD channels I can receive on my new HDTV. I am running the aerial through the DVD recorder to the TV. Can I run the aerial line into the TV and...
You might need a splitter (about 3 bucks at walmart) attach the Antenna to the side of the splitter with only one connection. Connect an RF cable to each of the remaining 2 connections. Run one wire to the DVR and the other to the TV. You can then watch one channel, and record on the other at the same time. You might not be able to record in HD if the recorder is not an HD recorder. Regular DVD recorders only record up to 500 lines, HD is rated at 720 or 1080 lines
Jun 02, 2017 | Pioneer DVR-320S DVD Recorder
On my cyberhome 1600 dvr want to view tuner of dvr on tv screen
Take your TV for a check by a good technician. Some IC have short circuited in the accident that occured.
Rate this...
Mar 22, 2009 | Cyberhome DVR 1600 DVD Recorder
Can't record from tv to dvd
I think you would have to run your sat line through the DVR-1600 first (Line In) then connect directly from the DVR to one of your TV Line-Ins (Audio R, Audio-L, S-Cable Video).
And then use the Cyberhome TV Tuner to record off your sat.
Jan 24, 2009 | Cyberhome DVR 1600 DVD Recorder
Sansui DVD recorder DVR 1038. Can I reset the recorder to factory settings?
Repost this in the DVD section to gain access to a more qualified set of experts in relation to this issue.
Jan 01, 2009 | DISH Network DVR-625 DTV Receiver /...
DVD recorder with NTSC tuner
Hey Whormd,
If neither your DVD recorder nor your TV has a digital (ATSC) tuner, they will not be able to directly receive over-the-air broadcasts after the DTV conversion is completed without the assistance of a set-top converter box. Please keep in mind that the official analog broadcasting cut-off date does vary by country. In the U.S. this date is February 17th, 2009, and that Canadian TV stations have until August 31st 2011 to make the transition.
Please also note that you will need one converter box for each device with an analog tuner, in order to watch one program while recording another. One converter box would need to be connected to the DVR, while the second converter box would need to be connected to the TV itself.
For more information, I would strongly suggest checking out the FAQ sections of the official DTV websites established by the Federal Communications Commission (FCC) and the Canadian Radio/Television Telecommunications Commission (CRTC):
http://www.dtv.gov/index.html (FCC)
http://www.crtc.gc.ca/ (CRTC)
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 10, 2008 | Pioneer DVR225 DVD Recorder
New TV hookup
Erica,
You should have no problem with this. I have provided a picture of your model below for clarification. One end of the coax will attach to the 3-4 OUT on the back of the receiver and the other end will go to the NEW tv's coax input. If your set has two coax inputs you may have to select the port that you connect to in the menu portion of the tv. If the new tv does not have a coax input you can use RCA jacks which are red/white and yellow and connect those to the TV 1 output on the back of the receiver and the other end to one of the inputs on the back of the tv- this will require you to select the input source you connect to again e.g AUDIO 1, AUDIO2 etc. If you have a VCR run the coax from the 3-4 on the back of the receiver to the antenna inon the back of the VCR -usually the top port, then run another coax from the output- bottom port to the coax input on your tv. I hope I have been of some assistance to you and Thanks for using Fix Ya. If I can assist you further please let me know.
Jim
Apr 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Cameras Logo
79 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
