Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
IT IS JUST NOT CLEANING PROPERLEY STUFF LEFT ALL OVER PLATES
  • AEG Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
awqre
Posted on Sep 29, 2010
I accidentally put Mr. Clean in my dishwasher instead of Jet Dry. So far no problems. The dishes even look cleaner. I'm just wondering if it's hurting us by eating off the dishes, or if it's hurtin
It depends on the food that's on the plates. Deep fried, fatty stuff is bad for you.
As long as the plates and the machine has rinsed with clean water (run a cycle with no soap) all will be well, well, except for your arteries if you keep wolfing down greasy stuff.
Oct 14, 2014 | Kenmore Dishwashers
Unable to remove back panel
There are two Philip screws located on the edges of the back. Remove them this will allow the back to be taken off. Then remove the two screws at the top bracket that holds the filter in place..Ypu can remove the filter and bracket No need to remove any more of the screws on the back . From there you will see the plates and another filter. You can get at them by removing the two screws on the left and right of the plates..You can take the plates and filter out for cleaning and change the bulb if needed....NOTE; the filter on the back is resting on a activation switch just make sure when replacing the filter and bracket is pushed down to activate or the machine will not work..good luck....
Mar 24, 2014 | Ecoquest Fresh Air Air Purifier
Carb not working properley
sounds like you didn't get the pilot jet /air screw / idle circuit clean.
the symptoms sound like the pilot jet needs cleaning.. the jet has a VERY tiny hole that's easily blocked or dirty
Mar 12, 2014 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Our dishwasher is only 4 months old. Sometimes there will be small particles of food left on some of the plates. Also when we wash glasses in this machine they are cloudy or dirty looking.
There are several reasons that the food can be left on the plates. If the washer filter is plugged (partially) then the food particles can remain in the tub and be re-deposited. This can also happen with a dirty sump. According to the specs, your filter is self cleaning, and has a food disposer. The link to your machine is here:
http://www.sears.com/shc/s/p_10153_12605_02213742000P
I think, in your case, a good cleaning would help. When the disposer isn't working well, the screen can be coated, and needs to be cleaned to be efficient. Your manual, accessible from the link above, (then select specifications, scroll down to another link) recommends a vinegar wash and is described there.
For heavy duty cleaning, you can (in this order): Add 1/2 cup of salt, 1 cup of baking soda, and 2 cups of vinegar. Spread the ingredients around the screen, one at a time, at the bottom of the tub. It will begin to foam. When it has quit foaming, add 2 cups of bleach, and run a hot cycle (Pre-heat the water by running the hot water faucet closest to the dishwasher until hot).
Best regards, --W/D--
Feb 12, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
My fabric softener compartment won't drain properley and always has water left at the end of the cycle - any ideas to clean?
yes this cleaning should be carried out on a regular basics,remove the compartment/drawer give it a small pull and it will come out easly.clean with warm soapy water once replaced put a [dishwasher] tablet into drawer and run a normal wash,done once a month this will keep you free from problems.adrian,,,,,,,,
Aug 19, 2010 | Asko W6461 Front Load Washer
Vanguard wall heater does not burn correctly
Hi the plates/burner needs cleaning out blowing then out with air line when off should help
Jan 26, 2010 | Vanguard International Infra Red - Medium...
Food left on plates etc
clean, clean, clean. check drain. bet the sink is slow.
Apr 26, 2009 | Haier Dishwashers
Ecoquest fresh air repair
Regardless of unit the purifier plates may need replacement. How are the plates cleaned? Could it be that there is a residue from the cleaning agent present after cleaning? With new plates there is a little oil on the plates to prevent oxidation when in storage or transit. A little rubbing alcohol would do the trick.
Make sure the plates are dry before putting them back into the unit.
If the plates are seated right and clean you should see a faint purple glow on the plates when the unit is on purify.
Let me know if that's the case.
Eric
Dec 18, 2008 | Ecoquest Fresh Air Air Purifier
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 | Dishwashers
Cleaning Ironing Steam Press
If it is not teflon coated sand it of with 400 grit sand paper. sand from front to back and it will create a nice grain and
this paper is so fine it will not scratch the surface. Sand it gently until the substance is completely gone. Do not do
this if it is teflon coated. Hope this helps you.
George
Jul 11, 2008 | Yamata PSP-990A Iron
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
155 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
