Question about Intel Motherboard
Display probelm my board has no display or beep , but when i remove the ram from the socket it gives ram beep,i find its out that ram are ok ,but when i reinstalled ram than no beep only cpu fan is ok and on keyboard two time bilink is seen
  • 341 Answers
I am not sure but it sounds to me like the ram is bad.
Posted on Jul 28, 2010
Testimonial: "your answer is helpfull but my ram are ok and i have test it on other boards"
Have you check your motherboard with other ram if so it means your board is having a problem
Posted on Mar 27, 2012
Power turns on but the screen is blank
Could be a couple things. If you hear everything start up then it's going to most likely be the LCD or the inverter. Steps I would take to verify:1) Remove battery.2) Remove RAM.3) Power on. If you get beeps then you know the logic board is responsive. If you don't then you have issues with the logic board.If beeps:4) Replace RAM5) Attempt to use an external monitor. If you get a display on that then it's the LCD or inverter. If you don't then it's the graphics card/processor (which is still on the logic board).If you get video on external monitor then you'll probably need to take it to a service provider to get repaired.
If you could provide me with a serial number I can give you more details.
Jul 28, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I have A dell gx270 desktop computer . i was searching on internet . Suddenly system hangs . When i restart computer it hangs on dell logo . i tried many time but it hangs on dell logo . i changed ram ,...
Firstly, make sure you installed the video card (if it has one) back into the same slot it was removed from.
If you are using on-board video, check the CPU is firmly seated into it's socket, you may have to remove the CPU fan to check this.
Next, check your RAM sticks again. Most (about 98%) of boot up issues arise from incorrectly seated ram sticks or ram sticks that have developed connection issues.
When you boot the machine, does it make any beeping noises..?
Usually, a single beep means all is ok. If you hear multiple beeps, then the bios is telling you about a possible fault and you should count the beeps for number and duration (long beeps or short beeps and how many of each and in what order)
Remove the ram and using some very fine emery cloth, gently remove any oxidisation from the contact pads to return them back to bright metal, then re install them making sure they are seated all the way down and the locking clips are fully seated too.
If you still have boot issues, I would suspect the ram sticks first and have them checked by installing them in another compatible machine, either a friends or at a repair shop.
I would suspect the board last so if the ram sticks check out as good, have a closer look at any other cards that may be installed, especially video cards and internal modems but also check out any network cards that may be installed..
If you are still not getting any display on the monitor, take the machine to a service centre or computer shop as they have the specialist equipment to check out the board electronically ( boot cards, scopes etc).
Let me know how you go and what you find..
swoop611
Dec 05, 2010 | Dell OptiPlex GX270 PC Desktop
Display probelm
After reading your issue,i am sure that there is problem with your motherboard.
as you cannot see anything on screen and you get power,that means your motherboard is faulty
so just get your motherboard replaced and it will be fine as before
Thanks
Jul 28, 2010 | Intel Desktop Board D845WN Motherboard
No ram beep is ok but there is no display
pls. replace with a new same rating RAM
Apr 06, 2010 | Intel Motherboard
Intel D945GCNL Board No display
Dear user, this problem can be coused by many things.
1, The memory you have installed is not compatible with your system.
2, Power supply failure.
3, Contact issue between the socket and the module.
Try thease:
Take a brush and clean the sockets.
Power on your computer without the memory modules, if you hear beep it could be a health signal :D.
Power off the system.
Clean your memory module pins with alachol or other cleaner liquid.
Wail till it dry, inster it back to the socket and move a little ud and down to catch ancontact.
Power on and now shold be work fine.
If this ain't works. Try other brand of memory, kingmax or kingston. They usually shipps with 99 of good modules from 100.
Good luck.
Mar 22, 2009 | Intel D945GCL Motherboard
NO BEEP, NO DISPLAY EVEN REMOVING OF RAM.
are you using socket 478 motherboard or socket lg775 motherboard? if lg775 mobo you using try to remove the cpu heat sink and put it back again make you put correctly lock it perfectly and try to switch it on
Mar 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel Server S5000VSA gives 3 beeps and no BIOS display.
According to the following document (pages 14-19) published by Intel .. That memory module is not listed as tested/working with that board.
Feb 19, 2009 | Intel S5000VSA Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
No display
Dear hubult,
There is issue with u RAM because when u remove the RAM it starterd beep it means u r RAM slot is ok. the problem is with u RAM pls change the RAM and then check it and one more thing before u change the RAM do one thing take out the CMOS battery and then restart the system after restarting the system shut down the system and then reconect the CMOS battery and start the system.
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
Intel Motherboard Logo
144 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
