Question about Canon DR-3080CII Path-Through Flatbed Scanner
Scanner is busy operation cannot be completed
3 Suggested Answers
  • 32 Answers
SOURCE: Canon DR-3080 CII Scanner
The (-4437) is not a familiar Canon error to me. It's probably generated by your scanning software as a generic message for a scanner not ready condition. If the light on the top of the scanner is blinking, the scanner needs service. If not, check the cable to the computer for solid connection or bends/breaks. You can also try running the Capture Perfect program that was bundled with the scanner to see if the problem still occurs and gives you a more specific error message.
Posted on Apr 07, 2009
  • 102 Answers
SOURCE: My scanner won't scan. I
This may mean that something is using it or that something is interfering with it. Try turning everything off, your computer AND your scanner. Wait a minute or two and then turn your scanner on first and the turn your computer back on. When your computer boots back up don't open anything except the scanner. If your still getting the message then there is something else (another attached peripheral) that may be interfering with the scanner.
Posted on Oct 29, 2010
I am using a software package called Readsoft Forms. I create form definitions for different surveys using this software. when I change to a different form definition to scan I sometimes get an error...
Please try USB connectivity instead of SCSI. It is lot easier and unlike SCSI, there is no sequencing required. (With SCSI, you need to start the device before you start the Computer). You can switch on the scanner when you want!
S. Mohan, Chennai, india.
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
Hello, I am getting the following error message Scanner is busy, operation can not be completed. Canon DR-6080/7580/9080C Driver Version 1.3.10502.17001 (-4437) I need some assistance. Thank...
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer, reinstall drivers and scanning software. Pls run scandisk on the Computer and ensure the OS is okay.
S. Mohan
Feb 22, 2011 | Canon DR-3080CII Path-Through Flatbed...
My scanner won't scan. I get the message " Scanner is busy, operation can not be completed. Canon DR-2010C Driver Version 1.1.10805.18001 (-4437).
Oct 29, 2010 | Canon DR-2010C Flatbed Scanner
I have just installed the scanner and software, however, when i try yto scan an error message comes up saying 'the action cannot be completed because the other program is busy. Choose switch to to activate...
Might as well try to power cycle the device meaning disconnect it from the computer , turn off the scanner , unplugged the adapter from the power source and then push on the power button for 5sec so that excess power will be drain and then restart the computer also as soon as your computer boots up connect the scanner .
ERNZ
Feb 03, 2010 | Fujitsu fi-5120C
No installation software, compatibility problem with windows vista business
Try VueScan at www.hamrick.com.  The software is compatible with over 1000 scanners on many operating systems.  Please remember to rate this response.  Thanks.
May 19, 2009 | Visioneer OneTouch 7100 Flatbed Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Trouble code
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Oct 23, 2007 | Lexmark X5150 All-In-One InkJet Printer
Canon DR-3080CII Path-Through Flatbed Scanner Logo
2,845 people viewed this question
old marine
old marine
