On my LCD the date shows o4/24,how I can change to the right date on the user's guide I cannot find thedate/time.
    Guru:
  • 1,342 Answers
Double click on the time. The Date and Time Properties box should open and you will be able to set it.
Posted on Apr 23, 2008
How do I set my watch
It all depends on the type of watch you have.
Manually, the time (and date) are set by releasing the crown wheel and turning it so that the hands move clockwise to the correct time. If you have a date function, you may have to cycle the crown wheel quite a few times to reach the correct day and date.
On digital watches, the user guide will indicate which buttons should be pressed to set the time and date. Refer to the user guide that came with your watch, go onto the manufacturer's website or go back to the store where you bought the watch and ask them to show you how to do it.
On smart watches, the time should be set automatically when the watch synchronises with your smartphone or wifi signal.
May 24, 2015 | Watches
Remove time date picture
Try to use menu and settings. Also, date stamp can be used only in very low resolution images, change your image resolution and quality back to this large/superfine setting. And you can find the information related to date stamp in user guides. Look for them here Canon Camera user guides and owners manual
Jan 23, 2014 | Canon PowerShot SD1300 IS IXUS 105...
Time and date won't save
Replace the date/time battery. See the instructions on page 87 of the advance user guide.
Jun 11, 2012 | Canon PowerShot A410 Digital Camera
How do I turn the date and time off?
Press the MENU button. Use cursor-left/right to select Setup. Use cursor up/down to select "Date Stamp." Turn the option Off.
You can see the User Guide here and the Extended User Guide here.
Feb 06, 2012 | Kodak C1530 Digital Camera
How to set small clock on right side of home screen
Select 'Menu' then select 'Settings' then select 'Date and time'.
Select 'Date and time settings' to set the date and time.
You can also scroll down in Date and time Settings and select 'Auto-update of time' which means your phone will automatically keep time using your phone network service.
User guide for Nokia 2730 can be found at:
http://nds1.nokia.com/files/support/apac/phones/guides/Nokia_2730_UG_en.pdf
Mar 11, 2011 | Nokia 2730 Cell Phone
How do I adjust the time and date etc.
IN THE OUTER PROFILE YOU HAVE FOUR BUTTONS,JUST PRESS THE TIME/DATE BUTTON AND IN THE CENTRE OF THE WATCH YOU FIND THE DAY(EG:SUNDAY)IS BLINKING,JUST PRESS THE OPPOSITE SIDE BUTTONS TO CHANGE THEDATE,AFTER CHANGING DAY,AGAIN PRESS THE DATE/TIME BUTTON NOW APPEARS THE TIME BUTTON(EG:11.00 HRS),NOW PRESS THE OPPOSITE SIDE BUTTON FOR CHANGING ......
THANKING YOU.........GOOD DAY
Sep 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I have 2 clocks (model 40009,40010)that have inaccurate time
I read the manual which said to depress the alarm button. That wasn't the right button but I found that depressing the button next to it, the DST button, that that fixed the problem.
Thanks.
Oct 24, 2009 | Equity Time USA 30731 LED Digital Electric...
How to set date and time on Canon FAX-L350
Maek sure machine is switched on and there is a display showing.
1. Open the 'one-touch' speed dial panel (plastic flap to right of main number keys)
2.Press the key 'data registration' The display will show "REGISTRATION 1. DATA REGISTRATION"
3. Press 'Set' key twice (lower right key on grey centre panel area). The display will show "DATA REGISTRATION 1. USER SETTINGS" after the first key press, then "USER SETTINGS 1. DATE & TIME" after the second key press.
4. Press 'Set' again, then use the numeric buttons to type in the correct date and time - you should get something like 11/01 2009 and 16:09 in the display (use 24 hr clock for the time).
5.Press 'Set' to save the date and time the display will show "USER SETTINGS 2. UNIT TELEPHONE #"
6. Press the 'Stop' key to return tot he machine's normal 'standby mode' .
7. Print off this webpage so that you can remember how to change the time for daylight saving time changes etc... or int hee vent of a power cut.
Hope this helps.
Aug 12, 2008 | Canon FAX-L350 Plain Paper Laser
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Apr 03, 2008 | NorStar M7324 Telephone
How do I change the time on Avanti 3020 telephone?
For the Avanti 3015 phone you have to
  1. push the feature button
  2. enter the number 82
  3. enter the time as follows
  4. Enter four digits for the current time (00 to 23 for hours and 00 to 59 for minutes).
    Enter two digits for the date (01-31)
    Enter two digits for the month (01-12)
    Enter two digits for the year (00-99)
    - The display shows the digits as you enter them - Press {SAVE}
    - The new time and date are displayed
Sep 28, 2007 | Lands Phones
Computers & Internet Logo
David Payne
David Payne
