Question about Cell Phones
When i plug my headphne and it only hear the left speaker intstead of the right i only hear one side only instead of both sides and when i try to play through my stereo bluetooth and its said you have to disconnet the wired headphone even tho the my headpne is out of the jack
  • 36 Answers
Sounds like your headphone's port on your phone is the cause.Try connect,disconnect and then reconnect the headphones for a few times to clear it up.
Posted on Jul 28, 2010
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
Only right side volume working wehn volume is low, when volume is high both sides work but distorted
It may mean that the connection for your left side speakers are loose or they are not connected properly. you can also try plugging the speakers to another music source (ipod, stereo, etc.)
If the same problem happens it is most likely a faulty wiring on the left speakers.
PS - if your computer volume software has the balance option make sure it's in the middle and not set to have output on just the left or the right side.
Hope this helps!
May 12, 2011 | Logitech R-10 Computer Speakers
I can only get the right half of the speakers to work, how do I get the rest?
switch the speaker connectors and see if the ones that work on the right work on the left. if they do then your amp is ok and the problem is either the wiring for the right side or the right side speakers. If the speakers don't work when you try this swap, then you have a bad channel onn your amp and will need a bench mechanic to fix it, (if you could find one). also make sure that you have a signal to both the right and the left, this can be tested by again doing a swap, take the left feed and put it in the side that is now working and if you hear sound then the inpurs are ok
Mar 17, 2011 | Denon AVR-1100 Receiver
Had about 4 pairs of the same brand of headset and after about 7 or 8 months lose hearing of sound form the left side. Always the left. their is no sign of tear in cable from out side and it cost a lot of...
The Left Side speaker unit(driver) of the headphone is different from right side. left side has more connections and soldering points, main cable goes to left side and chances of oxidization is more, because of cable movement(if cable goes to both sides of the headset, than it damages the side where cable movement is high). try to carefully open the headset and check the connectivity with multi-meter, If it is cable problem then trim the cable and re-solder. Or as you told you have 4 pairs, and you have broken ones. swipe the speaker unit (drivers). Besides both left and right drivers have different connections, it is possible with little soldering knowledge. hope you got it. thank you
Sep 02, 2017 | Labtec Radio Communications
The right side of the speaker is low, you can hear it but it's like there is no bass to it like the left side, sounds like the right side is like whispering to you but the left side is talking normally,...
If your subwoofer is placed to the left side try moving it to the right side or try to move it in the center. Otherwise if you are using a PC go to the control panel and click the sounds and audio devices icon. a little window will pop up and the button labeled speaker volum click on and reduce the volume for the left speaker and then turn up the volume on your speakers and see if that helps.
Nov 30, 2010 | Logitech Z-2300 Computer Speakers
I can just barely hear the audio coming from all right side factory speakers. left side is fine. all car audio is factory. No changes. Is it wiring or are the speakers going bad? Thanks
maybe the speaker is going bad but first try to replace extra speaker try to connect if still the same your car stereo is bad on the right ic output
Aug 06, 2010 | 2002 Honda CR-V
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
Left speaker port shorted out
I found that the part is called a speaker input and I was able to find one and am having it replaced. Thanks.
Feb 17, 2009 | Philips Magnavox 42MF521D/37 Television
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
RE: RCA RT2500 Receiver
take the cable of right speaker(which is ok)and put it instead of the left cable if it is ok-your problem will be in your left speaker or its cable-if it is not working the problem in your receiver output stage.(left channel path problem)
May 18, 2008 | RCA RT2500 System
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
