I have a Maytag model # PVAT234AWW Washer. It is only 2 yrs old and it won't agitate. We are trying to remove the front panel and cannot seem to get it off. Any suggestions????
The PVAT234AWW top-load has two spring clips at the top of the front panel. Use a sturdy, wide blade pry bar or screwdriver to pop the top off the two clips. The top is somewhat hinged at the rear, so the front part of the top cover lifts up.
You will see two hex head screws, one on each side. These hold the front panel in place. The front panel lower retainers are long spring clip types. The front panel lifts up and away from these two lower clips after the top screws are removed.
Posted on Jul 28, 2008
Had a metalic sound. Now it will not spin or agitate.
Posted on Oct 27, 2009
  • 240 Answers
Check for screws at bottom. few have them. otherwise paintscrapper /putty knife works between top and front panels. there are some alignment posts in there as well that are close to the clips, they prevent you from pressing the clips down. the actual clips are to the inside of those posts press hard and pull up or out at same time
Posted on Apr 24, 2008
Maytag washer mav4757aww was agitating a little then would stop and make a slight humming sound. Now it won't agitate at all , it just hums and starts to smell like something is getting hot. It will...
Unplug the unit and remove the front panel and look at the space between the motor and transmission find the coupler that connects the two together this could be broken. You may have to lay the unit on it's back to check this out. It's a cheap fix if its the coupler. Let me know.
Sep 27, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washer leaks after it starts to agitate. It seems to be coming from the front of the washer. Thanks for any help.
To find where the leak is coming from, remove the 2 bottom bolts on the lower kick panel and remove panel. Next, remove the 2 bolts holding the upper front panel and remove it also. Now, with the front panels removed, run the washer and look for where it is leaking from. Repost your observations.
Feb 11, 2011 | Maytag SAV365ZAWW 3.3 cu.ft.
Won't spin, agitator won't turn. Repair it or just get a new one? 8 yrs old.
Hello,if your washer won't spin first check to see if the motor is running, then proceed as follow.
1. If the motor is running, your washer probably has a frozen pump pulley or broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely or if it is frozen or stiff replace it.
If the pump belt is broken or looks quite warm, replace it but be sure to check the pump pulley before you change the belt.
AGITATOR: If the agitator won't turn, the likely cause is "Lid Switch" because if the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Jun 09, 2010 | Maytag SAV2655A Top Load Washer
My Maytag washer will agitate without clothes in it but will not agitate with clothes in.
The belt is not doing it's job. It could be that the belt is worn, if so a replacement can be bought from a Maytag dealer. It is also possible that the belt is just not under the proper tension. Maytag motors are mounted in a slide, and tension is applied by a spring. if the grease in the slide gets old and hard, the slide will stick making for a loose belt. To access, you'll need to remove part of the cabinet. Pop the top loose at the front, remove two screws at the top of the front panel, and release the clips at the bottom to remove the front panel. Free up the slide with some light motor oil and re-assemble.
Jul 12, 2009 | Maytag HAV3460AWW Top Load Washer
How to adjust new belt on maytag washing
sounds like you have a bad transmission. can you lift the top up so you can see what it is doing when it is trying to spin. does it adgetate and spin at the same time? If yes you have a bad transmission. also if you get 2 people one looking inside of the drum and the other turning the big pulley in one direction it should turn the whole drum in the other the agetator should go back and forth. Tell me what happens thanks.
Jun 10, 2009 | Maytag MAV4755A Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Washer filled with water-then wouldnt agitate and smells like something burning
All Maytags (greater than 2 yrs old) have belts that are prone to wear and slippage. (thus the odor) In all but one model is the belt is visible and replaceable beneath the machine. Simply lift and tip the machine back to gain access. In one model, the front panel will have to be removed in order to replace the belt. This is a good place to start, inexpensive and simple to replace..
Other causes for belts burning are:
1. Failed transmission
2. Failed water pump or debris stuck in water pump....
If I can be of any further assistance, let me know
reg501 the Fixya Team
Jun 18, 2008 | Maytag Washing Machines
Washer won't spin
Could be a worn belt,
Empty the machine and tilt backwards, you may need some help to do this.
Remove the belt and check, some times these appear OK but may have stretched.
Chech the agitator pully, try to rotate, will only move in one direction, see agitator moving as you do, get the person helping you to see this.
Check the motor moves freely on the tensioner, motor will appear to move 2".
Fit a new belt and try.
Apr 16, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
