Question about Whirlpool Dryers
I have a stackable washer and dryer and laundry detergent is leaking into my dryer (which is on top). How do I fix this?
    President:
  • 3,773 Answers
First check your WASHER. IT MAY NOT BE RINSING AND/OR
SPINNING THE CLOTHES DRY ENOUGH.
I would suspect not rinsing more tho.
Leo Ponder
imufo2@sbcglobal.net
Posted on Jul 30, 2010
Washerleaks when filling why
Good Morning Friend,
I understand that the washer on your Frigidaire laundry center, model# FEX831F, is leaking water while it is filling. Listed below are some options that you can check first.
    1)There might be a loose hose connection either at the faucet or on the washer. Check and tighten the hose connections. Also, make sure that the rubber sealing washers are installed. If the rubber sealing washers are not there, this can cause leaking.
    2)Check and make sure your houses drain pipes are not clogged. If they are, unclog the drain pipes. Contact a plumber if necessary.
    3)Make sure you are not using too much detergent and are using "HE" detergent. If you are either using too much detergent or not using "HE" detergent, this can cause oversudsing, which can cause leaking.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 22, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
hello Boonk
welcome to fixya,
We need to know the brand and model number to help you.
The year or age of the laundry center could prove valuable too!!!!!
You asked ,How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
Waiting for this info. huuum
Oct 08, 2008 | Samsung Dryers
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Jul 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Seperate washer and dryer
Unfortunately, your washer and dryer are part of a "laundry center". Which means, the two together are one system. They cannot be separated. You can still use the dryer, obviously. Have you considered fixing the washer?
Jun 21, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
