Question about Grilling
I am looking for a manual for a Kirkland Signature gas grill
I am looking for a manual for a Kirkland signature gas grill Model PC2600L
SOURCE: Kirkland Signature by Whirlpool Washer
There could be 2 possible issues, one, the simplest is the switch activated by the lid, look for a plastic "prong" sticking out from the lid, see where it goes and find a switch, use sometime of similar size and see if you can activate it. If that is eliminated then it is a plastic coupling broken, quite involve, need to remove the back lower section and inspect for this, Had both these issues myself.
Posted on Apr 01, 2008
  • 360 Answers
SOURCE: i am looking for a manual and parts list for a
Exploded view and parts here -->click here<--
Please take the time to give this solution a fix ya rating
clarkco
Posted on Mar 07, 2009
SOURCE: Whirlpool dryer will not heat properly
my dryer gives off heat when no close are in it. but as soon i put close in,the dryer will not heat up.
Posted on Mar 15, 2009
SolutionGuy
  • 331 Answers
SOURCE: Gas Grill
The "safety" inside the gas tank has tripped. Close the valve on the tank, remove the hose from the tank, reconnect the hose and SLOWLY open the valve on the tank. This should reset the safety.
SG
Posted on Apr 06, 2009
maddogsteve1
  • 18 Answers
SOURCE: My Kirkland Signature Whirlpool Washer will not agitate or spin
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
Posted on May 25, 2009
How to change burner on kirkland 720 gas grill
You should not need any special tools. The burners are usually held in place with screws If you take the top grills off, there may be a set of covers or shrouds over the burner unit. They usually just lift out. After you have removed those covers, study the burner unit and locate the screws, which are uasusally in the front.Lift the front of the burner and the back of the burner should come out with a little twist.
May 31, 2014 | Costco Kirkland Grilling
I have a new Vermont castings Signature Series 401 Natural gas grill. Even when the burners are set on high there doesn't seem to be a very big flame on any of the burners and with all the 4 burners on...
You may have a new VC Natural Gas grill, but I'm willing to bet that it has LP Gas Orifices in it, instead of natural gas ones. Sometimes this happens. It gets mismarked as Natural Gas, when in fact it's Propane.
To confirm this, remove a burner, then remove the orifice, It should be stamped for which gas it's for. It will say NAT or LPG or LP
If you find this the problem, contact the VC dealer you purchased it from, for No Charge replacement orifices.
Hope this helps you to troubleshoot and solve the problem
May 10, 2011 | Vermont Casting Signature VCS4028N...
I have a beef eater signature series 3 burner please advise instuctions for roasting pork
Depends on what your cooking.A roast of pork,I would brine for 3-6 hrs before hand,then use 2 burners for indirect.To get a better idea try one of these sites.Your making me hungry thinking of this :}
{I do a pork tenderloin in the smoker bacon wrapped,butterflied with stuffing,smoked with apple wood}
http://cookeatshare.com/popular/cooking-a-pork-roast-on-a-gas-grill
or
http://www.foodreference.com/html/rubbed-g-pl.html
Good Luck,hope it turns out well.
Dec 24, 2010 | Beefeater Signature S3000e 3 Burner
I have A whirlpool kirkland signature 4 cycle heavy duty xl capacity dryer that is not putting out the heat as it was A few days ago. I have cleaned out the vent area to the outside and still nothing. The...
did you clean out the duct that the lint filter slides down into?also remove the vent line from the back of dryer and start it,if it blows strong you still have something in the vent line,stick a leaf blower into the vent line and blow it out to the outside,if the vent is clear then you know there's a block in the dryer or you have a bad blower wheel,if the wheel is bad when you first start it you might hear the blower wheel banging around or make a sound that isn't supposed to be there,i don't know what a kirkland dryer is so next time open the door and send the model number off of the dryer.
Dec 28, 2017 | Dryers
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
Grilling Logo
132 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Marvin
Marvin
Are you a Grilling Expert? Answer questions, earn points and help others
