Question about Sony Ericsson Walkman® W995 Cell Phone
My phone wants charging so i plugged the charger in and its saying cannot charge please insert sony battery
  • 415 Answers
You may have an imitation battery and it will never work, if not then have your phone checked out
Posted on Jul 28, 2010
Sony xperia miro st.23i is showing charges but not charging I have try so many different charger but still not charging he keeping showing charging but if you removing the charger showing low battery and I...
These are my suggestions.
Possible issues.
The USB port on the phone is faulty and not making proper contact.
The battery charger you are using is not of sufficient current to charge the battery fast enough.
The charger/regulator circuit in the phone may be faulty. unfortunately it is not user serviceable.Have the phone repaired by a qualified technician.
Possible solutions
You may be able to purchase an external battery charger and use that then insert the battery in the phone.
Mar 26, 2015 | Sony Cell Phones
Every 5 minutes or so it beeps and says it is not charging although the phone is not even plugged into the charger. When you switch it on at first it says it is charging with the bar graph indicating this...
Hi, would have told you too replace two things on the phone,
The charger and the battery.....
But sometimes the charger port where the charger is being inserted into the phone might be faulty too,
So you will need to test for the charger port. Get a new charger and a new battery, and insert the battery and plug in the charger...if nothing happens, that means you will need repair the charging port....
Consult a phone repairer for help...
Hope that helped...
Feb 03, 2011 | Nokia 6110 Cellular Phone
My t715 sony ericsson device has a charging problem. every time i plug it in it seems to charge for about 5 seconds and then it displays "charging problem please remove charger" message and stops...
i have ah problem my t715 sony ericsson the problem i removed this charging pin the leg broken so i need solution my unit... can any one to give me solution charging jumper or diagram this charging pin!.....
Jan 30, 2011 | Sony Ericsson T715 Cell Phone
Wont charge tell me to insert sony battery
If Your battery wont charge instead it is requesting for You to enter a sony battery, then there is a problem somewhere that need to be checked. It is either the battery is bad and require You to replace it or the charger is not working fine or probably the phones connection port is bad. You need to run a test on the 3 before you can tell which is the problem. First run a test on the battery. To test the battery please follow the steps below:
  1. Turn off Your phone,
  2. Remove the battery,
  3. Insert it in another phone,
  4. Turn it on to see if it will ask you to insert a sony battery, if it does then it means the battery is bad and need to be replaced, but if it does not, then it means it is You phone that is not recognizing the battery,
To test the phone,
  1. Insert in another battery into Your phone,
  2. Power it on,
  3. Check if it will request for You to enter a sony battery, if it does, then it means the phone is faulty and the connection port is bad, but if it accepts the battery, then it means the phone is alright.
Finally, test the charger,
  1. Try to use it on another phone to see if it will charge,
  2. if it charges, then it means the charger is alright, but if it does not charge, then it means the phone is alright,
That way after carrying out the tests, you must have detected the problem and solved the problem.
Hope this helped. Thank You for using FixYa!!!
Jan 17, 2011 | Sony Ericsson Walkman® W995 Cell Phone
After charger is inserted , charging lights come on and battery indicater shows that is charging . After some time , an hour or so , a charging error message appears and says to stop charging . I purchased...
this problem was relating to your phones charging ic to solve this problem please change the charging IC WITH THE HELP OF A HARDWARE MECHANIC
Oct 22, 2010 | Cell Phones
Sony ericsson w995 won't charge. On attempting to charge phone says "Battery can not be charged insert a Sony Battery" (the battery is the original battery) once that screen goes it says insert SIM even...
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 16, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Take care.
Aug 10, 2010 | Cell Phones
My blitz keeps saying insert the battery when it already installe
the batteries dead. you need a new one because after the battery dies it wont awknowledge the charger or battery. same thing happened to me. honestly this phone is a piece of ****. youre gonna have a lot more problems ttrust me. im having a problem with it now.
Jun 30, 2010 | UTStarcom Blitz Cell Phone
Universal charger for w385 does not want to charge my phone. once i plug it into the phone, it says unable to charge.
hello,
the problem might be from the phone, the charger, or the battery.
to confirm it if it is the phone, try a similar charger on the phone and see what it says, if it does the same then it is the phone.
to test if it is the battery, try inserting the battery in another phone and try charging it tosee what it says again.
then try testing the universal charger by trying it on another motorola w385 to see what it says.
which ever it is you detect the problem from, then you can replace it.
May 27, 2010 | Motorola Mobility W385 Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Sony Ericsson Walkman® W995 Cell Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
