Question about Apple iPhone Smartphone
I changed the LcD and Digitizer of my iphone by my self it runs smoothly for couple of minute then the scree went white, i restore it from itunes but now it's dead. even itunes doesn't detect
  • 2,069 Answers
That is most of the times refered to as The "white screen of Death". now i would most probably consider your case as a hardware problem since that happened after replacing of the screen and digitizer. however the same problem could also happen due to software mulfunction and in this case, a few key press could probably fix it. I recommend you re-disassemble unit, check for any bad fixings, particles that could have stayed inside and re-assemble properly, connect to itunes again for restore incase its messed up. post results
Posted on Jul 28, 2010
  • jackdomos Jul 28, 2010
    yeah there was bad fixing inside the iphone i fixd up and restore again with the old broken lcd i can see the life on the screen with blur apple data transffer sign. what should i best do to replace lcd in good order so it work and don't die after couple of minute again.
  • Muzahura Frank Jul 28, 2010
    There is quiet a number of sites and even on youtube that have guides on how to dissassemble and replace iphones LCD and digitizer as well. I would recommend you get to those sites and follow it up carefully. begine by googling for example " iphone LCd". Good luck
How do I fix my iPhone it won't swipe
Never a fun issue . I suggest plugging into pc with iTunes. Create a backup. And restore phone. If phone is still not functional after restore. Then I would say you have a failing digitizer(part that detects touch). The glass digitizer and LCD screen are one part and can be purchased on eBay or amazon etc. Or if you have insurance. It's time to cash in.
Jul 21, 2015 | Cell Phones
I have iphone 3gs 32 gb when i make software from pc by using itunes it show for me box "There was a problem downloading the software code 3194" how i can fix it plss
if you got a white screen and nothing else , the lcd digitizer is bad , did you drop it ?. try to do a reset put it in dfu mode while hooked up to the computer itunes should find it in dfu mode and follow the prompts to do a restore to factory settings , to put into dfu mode hold the pwr button about 2 seconds then push the control button and hold both down for about 10 seconds let go of the power button but hold down the control button for another 10 seconds , itunes will find it in dfu mode and do the above .good luck
Mar 18, 2014 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Replace screen
If it was caused by your phone taking a knock then you are probably after damaging the LCD screen, iphones have 2 screens, 1 is the digitizer (touch sensor) which is a see through plastic sheet attached to the front glass of your phone, the other is your LCD screen which is behind the digitizer which projects the actual picture. You buy the LCD and digitizer together for the 4s, it is not possible to replace the LCD alone so don't get caught buying just an LCD on the internet, it is a difficult repair if you are not used to repairing phones. If you plug you iphone into your computer and itunes recognises your phone it is more than likely your LCD needs replacing. Have a look at a repair video on the internet so you can see what is involved in the repair and you can decide if you think you would be able to do it yourself.
Dec 30, 2013 | Apple Iphone 4s latest Model - 16gb -...
How can i fixed iphone screen glass
You can buy replacement digitizer from eBay and follow below
link
http://www.youtube.com/watch?v=8fujLMaxJsw
Aug 18, 2013 | Apple Lcd Display Digitizer For Iphone 4gs...
The bottom half of my touch screen wont respond to touch, i cant unlock it but it will allow me to turn it off, any solutions?
if part of your screen isnt responding to touch then it could be either software or hardware related, best thing to do it back everything up via itunes and if jailbroken cydia stuff through aptbackup, then do a restore in itunes (if jailbroken shift+restore for custom firmware)
Then once it has finished see if this has corrected the problem.
If not, then you have a fault with your digitizer. This is basically a film behind the glass of the screen which tells the iphone where you fingers are etc.
You can buy a new digitizer pretty cheap from ebay, just look up a guide on how to install it (you can keep your exisiting LCD) and this will fix the problem.
Apr 09, 2011 | Apple iPhone Smartphone
My daughter's 3g phone was dropped...need help
Make sure connections are all good to motherboard. If they are you may need a new lcd screen.
Mar 14, 2010 | Apple iPhone Smartphone
Touch screen not working on iphone 8gb cant put password
You need a new digitizer. Go to www.iPhoneSolutionsMiami.com
Sep 11, 2009 | Apple iPhone Smartphone
My iphone screen has gone completely white and cant do anything with it
You have one of 3 things going on here.
  1. Software related issue - If this is your case you're lucky! Just perform a hard reset and a restore by following the directions below.
Do a hard reset by holding down home and power buttons together until screen goes black. While holding down home plug the iPhone into your computer. iTunes should now prompt you to perform a restore.
2. Bad LCD - This would require warranty repair/replacement from Apple. If you're not covered you can google iPhone repair for a repair shop. If you want to do it yourself buy your parts on eBay. Not too hard of a repair if you are handy with electronics.
3. Bad Logic Board = Again if this were the issue you would have to use Apple repair under warranty or a 3rd party repair shop. You won't be able to figure out if it's a Bad LCD or Bad Logic board without swapping the LCD for a good one first.
Hope this helps,
Please rate me!
Jul 09, 2009 | Apple iPhone 3G
White screen with lines
It appears to be a sleep state that the phone enters into.
How, I do not know. If your iphone/ipod touch screen is
pure white...here's a simple fix, gaurantee to work.
Hold the power button, and the home button, and the apple
logo will appear....release both buttons, phone will resume back to
normal.
Jun 06, 2009 | Apple iPod touch
Apple iPhone Smartphone Logo
29 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
