Question about Dishwashers
Miele dishwasher G2870 scm. There is an F14 fault. I have cleaned the arms removed the waste basket from the bottom of the dishwasher and removed the two parts one with the large metal ball to expose the plastic wheel clog. There does not appear to be a blockage. I also removed the top arm and cleaned that out. I don't know what other inlets to check as the guide does not tell me exactly what an F14 fault is but explains F11,12,13. Can you help?
    Genius:
  • 1,447 Answers
F14 on your model of dishwasher is indicating a blockage, poor water pressure or could be a fault with the pump pressure level switch or circulation pump.
Filter and non return valve is cleaned of any blockages and if the fault persists have it service..
hope this help.
Posted on Apr 23, 2008
  • 3,037 Answers
Please be advised that F14 on your model of dishwasher is indicating a blockage, poor water pressure or could be a fault with the pump pressure level switch or circulation pump.
Usually the pump is the thing that needs to be replaced. Since you think that it might have been clogged, if the water wasn't draining and there was no clog then the logical thing would be the pump.
If you replace the pump, then I think you will have solved your problem.
Good Luck with this
Please let me know if you have any further questions otherwise, Thank you for using Fixya
Please don't forget to rate my solution since this is one of the biggest aspects of this website, have a good day.
  • 19,396 Answers
F14 indicates a fault with the pump
F14 fault. What do I do?
Miele Fault Codes
Different brand dishwashers have different fault codes. That said, this may well be your brand. It does list the F14 fault code as well as the others.
Jun 03, 2017 | Dishwashers
Miele g1220 dishwasher displaying F14
In my case, F14 appeared when the waste pump was not be able to exctract the waste liquids. This happened because lemon kernels (that I use to remove bad smells) has clog the non return valve and the circulation pump passage way. I followed the directions from manual to clean the valve. I found about 30 lemon kernels on the bottom of the dishwasher. After the kernels removal and valve cleaning and refitting, my dishwasher operated as usual.
Mar 11, 2012 | Dishwashers
Piece of glass dropped through the filter housing when cleaning. Now there is a sound like the motor is jammed.
Hi ghedinger,
Seems something is stuck on your drain motor, now to thoroughly clean the unit and part, do the following:
- Remove as much residual water as possible from the sump and drain hose.
- Open the door.
- Remove the bottom basket.
- Remove the bottom spray arm.
- Unscrew the bottom spray arm flange.
- Remove the filter combination.
- Lay the dishwasher on its back.
Now you will see the Drain pump, like so:
Now you need to remove the drain pump from the housing to clean it thoroughly:
- Disconnect the pump plug connections.
- Open the safety retainer clip with a screwdriver
- Turn the pump clockwise and pull it from its holder
Now clean the impeller area, and then re-fit everything (Remember: When refitting, apply a little water or soap solution to the pump seal as a slip lubricant.) Then Test
Hope this helps :-)
If you found this solution helpful, please rate accordingly
May 07, 2011 | Miele G2732SCIWHWH Dishwasher
F14 fault on Miele dishwasher
Hi
F14 means a fault on the heater pressure switch or the water intake.
It could be that either the switch is faulty or circulation pump is blocked, you can check if the pump filter is blocked
Dec 18, 2010 | Miele Dishwashers
F14 problem with miele
this fault means low pump pressure in the circulation pump due to foreign particles jamming up the pump. you would need to remove the unit and tip it on it's side and remove the base plate and the pump and clear the blockage.
Aug 26, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 code Miele Dishwasher
This fault is low pump pressure. more than likely you have some foreign particles jammed in the circulation pump. you would have to remove the unit, tip it on its side and remove the bottom plate and remove the circulation pump and clear the blockage. the unit will start and stop and not work until the pump is clear.
Aug 14, 2010 | Miele Premier-Plus Built-in Dishwasher
F14 problem with miele dishwasher model G2270SCVI WOULD be grateful for your assistance asap as nothing in manual explains what to do. many thanks
Hi F14 is when the pump pressure switch does not operate. This can be caused by several things. Circulation motor blocked or defective. Insufficient quantity of water in appliance.Most commonly it is debris in circulation pump.This will require motor to be removed and cleaned.appliance will have to be un-installed
Jun 17, 2010 | Miele Premier-Plus Built-in Dishwasher
What is the error F14 in a Miele dishwasher ?
The error F14 in your dishwasher is due to water intake fault with heater or circulation pump, or something like that. The circulation pump would have been clogged. Try to clear it and your problem will get fixed
Apr 04, 2010 | Miele Premier-Plus Built-in Dishwasher
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
1,398 people viewed this question
Top Dishwashers Experts
