Question about HP Compaq nc6220 Notebook
'When the stand by button is pressed than the screen starts blinking when again it is pressed of my nc 62620 laptop
  • 808 Answers
Its the problem of ur lcd or VGA
Posted on Jul 28, 2010
How do I set the time on a KADIO KD-3806 digital clock
Earlier FIXYA question:
sachin_arane
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Mar 18, 2018 | Car Audio & Video
For the last 3months,my dell vostro 1088 laptop has started giving a lot of trouble.While i'm doing working on it,the screen suddenly starts blinking and it all goes white within a second.This pro
  • Remove the battery and disconnect the power cord.
  • Press power button for a few second.
  • Connect the power cord. Press the power button to start and then dock the battery.
  • White screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can arise with the motherboard or the screen might contain a defect.
Aug 22, 2012 | Dell Vostro 1088
Beachcomber hot tub pump 2 wont shut off
Stop button on your control panel is malfunctioning or defective; not acting as a normally close (NC) contact again.
It has to be replaced.
Oct 12, 2017 | Pool & Spa
Set time on vector lorus digital watch
Stand on one foot, while patting you head and rubbing your stomach... AND THEN... hold the lock/unlock button until the screen changes....the press the start/stop button which should get the seconds blinking so now you can begin to change things, switch to min/hr etc by pressing start/stop again. The orange run/rest button actually does the changing. good luck!
Dec 21, 2011 | Watches
Bottom right button is light, not EI. top left is adj button left is mode top right is st/stp. I can't set time and date and can't turn off my alarm
hi..
El stands for
To set the time
  1. Press and hold [ Adj button ] till the digits on screen starts blink.
  2. Now Press [ Mode Button ] repetitively to cycle through Hour -> minute -> Seconds
  3. Press [ ST/STP button ] to adjust the value. Each press will increase the value.
  4. Press [ Adj Button ] again to save the changes
To set the alarm
  1. Press [ MODE Button] till it displays Alarm Time.
  2. Repeat steps 1 to step 4 as described in 'To set the time'
  3. Different watches have different procedures to active the alarm. Common method is pressing a button briefly.
    Since model of watch is not specified, Try pressing [Adj Button] or [ST/STP Button].
Mar 18, 2011 | Watches
KADIO KD-3806 Model watch. How can we set date and time.
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
How do I change time on Kadio clock 3805, thanks ?
I hope it will help you..
May 15, 2010 | Watches
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
Wireless won't connect Compaq nc 6000
Try pressing the "fn" button + find a blue mark with antenna or stg. like it. When you press them toghether you should see the LED on your laptop start blinking or just got lit...
Mar 01, 2009 | HP Compaq nc6000 Notebook
HP Compaq nc6220 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
