Question about Motorola Mobility RAZR V3
No sound! I can hear ringtones and my phone vibrates, but when I record a sound or video, I cannot hear the sound at all. What's going on???????????????????
    Sergeant:
    Champion:
  • 283 Answers
Your mic is faulty,, bring it to the pro's, you can do it but you can also damage ur fone, its in the lower section of the board you can clean it by cotton buds and a thinner,., but the flex is case sensitive so it's better go to the pro's
Posted on Apr 25, 2008
When i recieve a text message there is no ring tone or vibrate
plz check your sound setting.for that
instructions are:
1. go to your phone's "setting".
2. enter into "sound".
3. "ok" or "click" on "vibrate".
4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
Aug 17, 2012 | Samsung SGH Cell Phones
Cannot hear mobile ringtone. It is fully charged but get no sound out of ringtone menu.
Hello ! Make sure you do not have your phone in vibrate mode. If so, then turn it off and you should be able to hear your ring tones. Hope this helps !
Sep 06, 2009 | Lands Phones
Can hear no sound during any form of playback
mybe she turnd off the sound try to turn it back up, on the side there are these buttons that go up and down, click on the one that goes up.. hope this helps
May 27, 2009 | Samsung Eternity Cell Phone
Cant hear ringtone when sumbody calls me
hi
well its could be possible that somebody has changed your phone profile settings
go to phone profile settings it could be in meeting or silent profiles....change that to normal or loud settings....or manually edit the current settings
hope it helps...if you have tried that let me know other details...and we will take it from there
Cheers
May 24, 2009 | LG enV VX9900 Cellular Phone
NO AUDIO ON lgCU720!! HELP ME!!
change your speaker in your cellphone
May 04, 2009 | AT&T LG CU720 Cell Phone - Silver
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
Ringtone volume problem
do you have it on vibrate along with the ringtone? sometimes they place the vibrate under the speaker so you can barely hear the ringtone if it's on vibrate..
Jun 28, 2008 | Samsung SGH-D600 Cellular Phone
Motorola krzr k1m stuck on vibrate
So my girlfriends phone wouldn't stop vibrating either...so I just threw it on the carpeted floor (throw it somewhat hard, obviously not hard enough to break it).....then the vibrating stopped.....worth a shot I guess if you don't want to go through the hassle of sending it in.
Feb 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
No sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility RAZR V3 Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
