Question about Razor E200/300 Electric Scooter Battery
We have A 300 razor battery scooter but do not have the battery pack or the charger.
    Novelist:
  • 184 Answers
How about this one? Razor e300 scooter battery charger - $17.99
Posted on Nov 22, 2010
  • 38 Answers
Buy a replacement battery pack and charger at razor.com or http://electricscooterparts.com/razore300.html
Posted on Aug 18, 2010
Have an e100 razor electric scooter. it has not been used since I bought for a couple of years. I got a new e100 charger and tried to charge but I noticed that the charger's does not activate either red...
Most equipment running on rechargeable batteries have one thing in common: if you let the battery sit there for long periods of time without recharging, the charger is not made to bring the battery back up to spec. The battery pack, if it is still good, needs a "kick" or "boost" from some other strong supply to get it started.
The other solution would be to replace the battery pack all together. If you have a friend with a similar scooter, you can try your new charger on his scooter to see if it works. Hope this helps!
Oct 21, 2013 | Razor E100 Electric Scooter
Where can I buy a new battery charger for my E200 Electric Scooter
Wheel Gears provide the best Review of the Electric Scooter; customers can view the multiple Reviews different Electric Scooters and they have a chance to select best one. http://wheelgears.com/
Wheel Gears
Dec 11, 2012 | Razor E200/300 Electric Scooter Battery
I have a razor 300 i charged overnight wheel turns but wen i get on it it wont pull my weight im 10 yrs old but it works wen walking at side ov it please help
check your charger and batteries with a multimeter and make sure that they are showing the proper voltage, also visually inspect the batteries for bulging or swelling, probably one or both of the batteries are bad
Jun 10, 2012 | Razor E200/300 Electric Scooter battery -...
Just wondering if I can buy extra batteries and charge them without them being in the scooter and how hard is it to change out the batteries, my goal is for the kids to ride one one set while the other set...
Depends, some tabs are directly soldered to the batteries themselves so you will need a soldering iron to remove the tabs. After that, it wouldn't be too hard to remove and replace.
Keep in mind that these take 2x12volt batteries and these lead-acid type batteries may take a long time to charge depending on the current your charger is supplying.
If you plan to charge the two batteries with the stock charger, then you would have to wire the 2 batteries in series for 24volts (stock charger 24v) and for convenience you may also want to head out to your local electronics store to see if they have the female socket that the charger goes into, and possible some wire, connectors/tabs that attach to the batteries and possible some small alligator clips if required.
Nov 21, 2010 | Razor E300 Scooter
My sons razor e200 dies quickly. I have changed the batteries, brought a new charger. I have checked the connectors and the tires are not flat The light is green but after 25 yds, turns and says needs to...
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
Aug 15, 2010 | Razor E200/300 Electric Scooter Battery
What do you do when ur razor e200 electric scooter stops working?
First try charging the battery, if that doesn't work then replace the batteries with replacements from razor.com. This should solve your problem
Jan 15, 2010 | Razor E200/300 Electric Scooter Battery
E20 razor rocket electric scooter will not charge and someone said you need to insert a fuse but it doesnt tell you were or how. i have only purchased this as a christmas present for my daughter but it...
If it is a fuse problem then try looking for a fuse box in the controller or charger. If not then take it back, unless stated in the manual that you need to enter a fuse before it will charge, the scooter should charge right out the box.
Another thing you might want to try is to turn the scooter off before charging.
Dec 28, 2009 | Razor E200/300 Electric Scooter Battery
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Razor E200/300 Electric Scooter Battery Logo
532 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
