Question about Intel Desktop Board D845WN Motherboard
Sir, my motherboard has problem that its display is not comining only ram bip is heard when we remove the SD Ram from socket . And i find out the ram from other board thats ram are ok
  • 808 Answers
Its may b the problem of ur VGA or processor so 1st of all chek ur VGA
Posted on Jul 28, 2010
My Motherboard (D865GLC) On for the moment and then turned off. plz Help
Posted on Sep 17, 2011
My motherboard is running in good condition i.e about fan and processor but it is not showing
Posted on Sep 13, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
If you it's the problem with your VGA card then you can get cheap internal vga cards from amazon and ebay.
Best Regards NextDoorNerd
Posted on Jul 29, 2010
Bip long no start up
there maybe a problem with RAM, try to release the RAM, clean the pin with rubber if its dirty, then place it again in the socket. Bip long no start up can be sign that your RAM not correctly installed or its already damaged.
hope this useful, regard riyan.
Mar 29, 2011 | Gigabyte Giga-Byte: GA-8VM800M-775...
My Toshiba X200 doesn't show any image.I've bought a new motherboard, but still no image appears.The tech that told that the problem was with the motherboard (that was supposed to be burned).Now he tells...
enable what? BIPS? never heard of it in the last 10 years, are you sure you are dealing with a PC tech there?!
Have you tested that the RAM on the computer IS OK?
Have you tested that the Video card on the machine is OK?
has any real troubleshooting been done on the machine?
if he just told you the motherboard was burned without doing any other testing you are dealing with a fraud.
Nov 07, 2010 | Computers & Internet
Istall the ram but do not desplay ram is out of socket and than buzzer 3 bip I was install Ram to other mother board Ram is ok please solve the problem
It is the wrong speed ram for the other motherboard for instance 133 sdram, 100 sd ram, pc2700 ddr ram, pc3200 ddr ram etc. you will have to see what type of ram is acceptable in your new board.
Feb 15, 2010 | Intel D845GLLY Motherboard
RAM Problem
either the ram is faulty or not compatible try using in a different board
the motherboard will beep with no memory in
Jan 17, 2009 | Intel Motherboard
RAM Problem
The most likely cause is the RAM is not compatible with the motherboard.
Jan 17, 2009 | Computers & Internet
Hi sir i have an acer aspire 5101 which bips when i swtich it on and nothing shows on the screen.i have checked the ram an hard dive and they both ok
1st step you can check how many bips you hear, if continous bips , checks your vga by change with other if you sure that your ram and hd is ok, 2st if problem isn't solved ,remove all your card and clean all contact part all card with liquid cleaner, pci slot vga slot ram slot and processor socket after that you can try to assemble your card again , ok good try
Sep 26, 2008 | Acer Computers & Internet
Intel 845 chipset MB of Kobian make
try ramsticks individually (one at a time) in each of the memory banks until you get a post on the screen. if you don't get a post, then the memory might be parity and the board needs non-parity ***or vice versa***. Also, find the jumper on the motherboard for a bios reset, and reset the bios, then perform the previously stated memory tests.
Sep 26, 2008 | Intel D845GLLY Motherboard
Ram when i upgrade 128 sdram to 256 sdram in intel 845glly it shows spd
It is not seieng the ram, try swapping the ram around or leave out the 128MB, just put in 256MB, if no boot then the ram is not compatible or faulty, not all ram sticks work in all motherboards.
Sep 08, 2008 | Intel D845GLLY Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Intel Desktop Board D845WN Motherboard Logo
137 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
