Need schematic for Phase Linear 3000 Series ii preamplifier. Unit is only producing a 120Hz hum.
SOURCE: Phase Linear UV8
I have same problem with same uv8 but i use remote to activate am/fm then hit setup on rem.enter 543210 and a new menu came up. ( listening for the beep after each 3 is pressed ) select the hammer in upper left hand corner of screen, select brake bypass to on, then hot the X near bottom os screen. this works for me it should work for you.
Posted on Jan 12, 2008
SOURCE: phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Posted on Dec 28, 2008
SOURCE: Unlock region code on my Phase Linear UV8
I had the same problem and I was able to fix it myself. call me and I can help you over the phone 951-334-2297 ask for George.
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: i need a remote for my jensen phase linear uv8
Get one off of ebay. Just received one for bout 30.00 Good luck
Posted on Jun 08, 2009
  • 6 Answers
hook the pink wire up to the ground and there u go
Posted on Nov 10, 2009
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
Free manual for mosfet phase linear upa424 240watt amplifier
You do have 12 volts connected to the remote connection, correct?
Dec 11, 2013 | Phase Linear UPA424CS Car Audio Amplifier
Phase linear uv8
Hola Hope this might help a little. You may have to read. Sorry, I can\'t post too many pics or video, but this link should help I hope. The link provides details and goes over the wiring. If not, google it or check on YouTube.
Instruction Manual - Page 1
http://www.helpowl.com/q/Jensen/UV8/Technical-Support/phase-linear-uv8-schematic/9778
May 10, 2013 | Audio Players & Recorders
I need the color coded wiring diagram for a linear uv9 rear plug
  • If you have any comments feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 15, 2011 | Car Audio & Video
Grounding hum
60 Hz hum? May have a grounding problem. can you turn the power plug around or is it a one way plug?Any ac or dc voltage between unit and control/poweramp?Can you ground unit? Check for voltage first.
Oct 06, 2009 | Behringer FBQ6200 Home Equalizer
Service / ownersmanuals phase linear 400 series
Can you please specifiy which Phase Linear model you are interested in? The outputs vary from model to model. Also, is there a specific problem that you are having? Any details you can provide will help us to post more details.
I am not aware of the service manuals being available on line at the moment, but will research this a bit more.
Thanks,
Dan
Sep 20, 2009 | Audio Players & Recorders
M&K series mx200 subwoofer humming
There are a couple of possibilities. The first one is just moving the ac cord that goes to the power supply away from the board by tucking it into the insulation. The other is you may have a bad (oscillating) STK- 4050 output IC which is availabe from MCM electronics. The power supply caps may also need to be replaced.
Dec 02, 2008 | M&K Sound Mp Series MX-350 MK II THX...
Humming noise thru my speakers
You are getting engine noise through your amplifier. To solve this problem you will need to install a filter in-line with the DC path, or install a voltage regulator in-line with the DC path.
Sep 08, 2007 | Phase Linear UPA424CS Car Audio Amplifier
96 people viewed this question
 Grubhead
Grubhead
