Question about Samsung SCX 4521F All-In-One Laser Printer
Paper jam How do I clear a paper jam in Samsung SCX-4521X
  • Samsung Master
  • 3,530 Answers
Hi. This could be sendor is failing or there is a jammed paper on you printer.
How to removed jammed paper
1.Unplug all cables (USB and power)
2.Turn around the printer
3.In the back there should be a small door that on my printer (SCX-4300) flips upside.
4.Look for any jammed paper.
5.Pull out the jammed paper.
Here's how to fix the sensor
Unplug everything from the back and then remove the four screws from the back panel. Pull the panel out but watch that the on/off switch doesn't hang the cover up.Once off, I removed the screw from the mount holding the right end of the sensor stick while holding the mount in place with my finger. When the screw is out, lift the mount up and carefully slide it off of the stick. Carefully rotate the spring, topside away until the left side of the spring catches the sensor piece. Now rotate the other end of the spring once more around the stick and while holding it at the top of the stick (12 o'clock) slide the mount back on. With the mount in place, release the spring and it will come to rest on the mount. Refasten the mount and check for light tension on the sensor. If it pushes forward when you release it, you're good to go. Refasten the back panel, attach all wires and enjoy.
Have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jul 28, 2010
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam in exit area
Hi
Disconnect it completely from power and re-connect again.
Sep 16, 2012 | Samsung SCX-4300 Monochrome Laser...
'paper jam' message - Printer not working!!
Clear all paper jams from the front and the back areas inside the printer. Then, turn off and restart. It should reset itself.
Aug 10, 2017 | Samsung SCX 4200 All-In-One Laser Printer
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam-2
samsung scx-4521f paperjam2 check inside
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
[no paper] in SCX-4200
there 9is a paer sensor which senses when there r papers ,prob might b that either it is not functioning or on of the sensor is depressed
Jul 29, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
573 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
