Hi We have a second hand Rinnai Convector 404 with no instruction manual. We cant get it to stay on we have had it looked at but it came back to same so we dont know if it's us or the heater. We can push the button down (with maintained pressure) it igintes and pumps out good heat but as soon as we take our fingers off the button all lights go out and the heat stops! any suggestions please.
    Novelist:
  • 120 Answers
This sounds like a faulty flame failure device. Fairly old heater this one. I have a manual on PDF but I don't think it will help you fix it.
Just found a link to users manual
http://kitchen.manualsonline.com/mdownloads/5c252c12-7d1c-42c8-8b7c-dabe16fa65ca.pdf
Have a look but best advice is get someone to have alook at it who knows the unit and can get spares as I'm pretty certain your going to have to fork out a few dollars on this one.
Posted on Jul 29, 2010
How can I clean inside a rinnai convector 417 gas heater
http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf
Beside cleaning the filters with a vacuum, There are no instructions on how to clean the inside of the heater. The back and front panels would need to be removed. Unless you are confident to remove the panels, just blow it out as you ahve done and make sure the filters are clean.
May 03, 2014 | Heating & Cooling
How do I clean inside my rinnai convector 417?
The owner's manual at http://rinnai.co.nz/tradesmart/upload/files/productfile/portable_convector_rce417_operation_and_installation.pdf on page 10 says to vacuum both filters weekly. It also warns not to wait for the filter lamp to come on since overheating may occur.
May 03, 2014 | Rinnai Water Heaters
Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
Jun 01, 2009 | Rinnai Vent Free Gas Heater/
RINNAI CONVECTOR 417 Natural gas heater 17.5 MJ Wanting to know if this is a decent model. Anything that may cause you to avoid buying this model? And about how old would this model be?
The 417 service manual is dated 2003, so they're no more than 7 years old.  You can download the operation & service manuals here:
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/161.pdf
www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/161.pdf
May 06, 2009 | Heating & Cooling
Rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Jun 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
332 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
