Question about Garden
I have a 13AN77KG011 Model troy-bilt lawn pony from Lowes My trouble is while the engine is running and I start crusing around the yard it does great! Butt as soon as you put a load on it the engine starts doing a High and Low reving of the engine. We sent it in and they told us that the govener sprocket inside the engine block.any sagestions on how to fix this problem?
#1 Taper
  • 1041 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 127 Answers
SOURCE: HOW DO I GET A MANUAL FOR LAWN MOWER AND ENGINE?
please double check model # and let me know
after the g sholud be a #then 11
13AN77KG_11
Posted on Jun 30, 2009
panilling9
  • 284 Answers
SOURCE: I have a Troy-Bilt Pony riding lawn mower and the
there is a sealant called slime it is green in color at lowes or depot or walmart read directions and install
or you can buy a inner tube and fix it
tube size is based on tire size
check inside of the tire before the tube is used if you go that route to be sure there is nothing to puncture the tube.
you can buy string type plugs to plug a leak if it is in the tread
use windex or equivalent to search for a leak
if its leaking around the rim remove tire and completely clean the rust from the inner rim where the tires bead seats against the rim when inflated.
Posted on Sep 16, 2009
Testimonial: "Excellent advice"
mickey813
  • 472 Answers
SOURCE: Troy bilt lawn tractor that will not go in forward-just grinds
sounds like the trnns has some thing lose in it you will need to get to the shop
Posted on Oct 15, 2009
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
What year is a Troy bilt 13an77kg011 serial 1b129b80291
Im gonna say 2012. You can reinforce that by checking the first two numbers of the 'code' on the motor. Not the chassis numbers under the seat but the engine numbers on the engine?
Aug 26, 2014 | Troy Bilt 5.5hp Self Propelled Mower
I have a older troy don't know model number i need a carb kit
You probley have a briggs & stratton engine. If so, look for the engine model number which will be on the cover. You will need model number and type number. Your carberator will be part of the engine specs. Then you can go online to
mtd/parts
and find the kit you need or take model and type numbers to your local lawn mower dealer and they will either have it in stock or order it for you. Cost is around 15 bucks.
May 28, 2010 | Troy-Bilt Pony Garden Tiller
Lawn mower
Always start by checking the spark plug. If you are getting spark and still not starting, it's probably a carburator problem.
May 06, 2010 | Troy-Bilt Pony Garden Tiller
I have a Troy-Bilt Pony riding lawn mower and the tire was low when I started using it. The tire ended up getting flat and now it won't seal when I try to air it up. What can I do? Is there a sealant I can...
Sep 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Tilller will not run
Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
If all else fails, you can call Troy Bilt at their # provided on the site.
Hope this helps.
Apr 29, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
277 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
