Question about StarTech.com StarView SV211K 2-port KVM Switch
Eurovox cass/radio in 2003 Massey Fergerson tractor ( factory fit).....disconnected battery , radio not working , displaying code 1 ???? how to I rectify??
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • StarTech.com Expert
  • 191 Answers
On the manual you will have a slip on it with the radio code on it it will be a 4 digit no as you dissconnected the battery the radio presumes it was stolen its a safety feature
Posted on Jul 30, 2010
My Massey Fergerson 1540 tractor won't start. I suspect it's the fuel pump is the reason.. How do I troubleshoot the fuel pump?
Get your self a wiring diagram and check to see if the fuel pump relay is getting energized when the engine is being cranked to start.
Jan 01, 2018 | The Toys
My odyssey 2003 is showing code err for the entertainment
Does the radio work at all. or is the cd player the only issue.? most of the time you need to enter a radio code to unlock the radio. If you enter it wrong to many times it will display error on the display.if you dont know the code then you can call the dealership and get the code after you do the following below to get the serial number.
Press and hold 1 and 6 on the radio while still holding the 1 and 6 press the power button. At this time it will read off serial number
SOUTHERNELECTRONICS.COM
Apr 02, 2015 | 2003 Honda Odyssey
Radio display light goes off when headlights switched on
You will need to either buy the correct iso adapter or run ignition live to display wiring.
Oct 25, 2017 | 2003 Ford Focus
Eurovox max v gone down need codes for 28th june 09
Hiya Sharon, I've got no idea if this'll work cos I don't kno if the EuroVox has any similarity to a Starvew box but as it does the same thing thought it might be worth seeing if U could do the same but hopefully it'll work for you too - good luck :-
Subject: Star View 3 The Box Super when channels discappear ;o) 1. Press menu then Factory Setting & Enter code 0000 to reset. 2. Exit to main menu & enter 1570 to get into the CASS SYSTEM & turn EMU on 3. Reinstall channels (Goto Installation, Cable network (try TW first & if no channels try NTL then C & W and so on - I'm with Virgin & used the setings for TW) & Voila ;o) Nb: You may have to redownload channels so reconnect yr box to the computer & follow the link below http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess & press download !!!
Jun 28, 2009 | StarTech.com StarView SV211K 2-port KVM...
Disconnected my battery to recharge it & cannot get a code to get my radio working. It's a eurovox, nothing flash, fitted in a Holde Rodeo Ute
Call the dealer with the last 8 of the vin and they can sometimes provide you with a master unlock code but most of the time they want the money to do this.
Aug 31, 2008 | GMC R2500 Cars & Trucks
Radio code won't work
Yes I've had the same problem you need to switch off the Radio and disconnect the battery again - Leave battery disconnected for about 5 mins and reconnect. then switch on the radio and you should have code displayed. Then type your code number in and away you go.
Jul 13, 2008 | 2003 Honda CR-V
Delco factory radio display is saying loc
There is a code. This usually happens when the battery dies, when you disconnect the radio or disconnect the battery. Unfortunately only the dealer or delco repair shop can unlock it.
have a great day!
May 28, 2008 | Car Audio & Video
Car radio pin code
Hi pat... bad news I'm afraid. You need to get the code from Eurovox. There is a way to change/defeat the code, but it involves having the thing apart on the bench and actually fitting a new memory chip to the radio that does not have a code. I used to do this if someone left a unit for repair and we were not left the code. I have cut and pasted the FAQ from Eurovox's site for you, Click the link to their code request form. There are also instructions on how to enter the code
And as always, the bastards charge for the info. Sorry I couldnt actually give you a code. I used to have charge $60 to recode a radio back in the day by rechipping it.
Why is my radio not working after the battery was disconnected/replaced?
The radio requires a security code to be entered. (also known as PIN number). A security code is either 4 or 6 numbers long for most of Eurovox Units.
How can I obtain my security code?
Download the Security Code Request form located in the Downloads section. Fill it out and send it in via fax or email with proof and payment. The serial number & model number of the piece of Eurovox equipment is essential. A new security code card will then be mailed to you and your details will be registered in our database.
Why does Eurovox charge for supplying a security code?
Security and administrative reasons. We enter your details in our database so if you lose it again you only have to identify yourself and give the serial number and we will give you the security code again, we also send you a new code card.
How do I enter my security code to my Eurovox radio/cassette/CD Unit?
Refer to the owner's manual of your equipment. Turn ignition key to 'Accessories' & a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' & so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
Why has my radio got horizontal lines on the display & is not responding to any buttons?
The radio has had 3 incorrect security codes entered & is now in lockout mode. For recent model radio's leave 1 hour (some radio's require ignition key to be on accessories). For older model radio's, remove power to radio by either unplugging radio or disconnecting the negative lead on the battery for 1 hour.
My radio will not accept my security code?
(1) This radio may have been replaced and now requires a different security code
(2)The security code you have been supplied is wrong.
(3)This radio has an internal fault. To check if radio works there is a temporary test code '1111' or '111111' can be used for most of Eurovox Radio. This only lasts for approx 3 minutes.
How do I enter security code to my overhead DVD/Screen combo unit?
Using the <<or>> buttons on the overhead console, scroll up or down to select the first number. Once the correct number is shown, press the ENT button. Repeat this procedure to enter the 4 digit code. As each digit is entered, it will be shown on the display.
Why does "Code Input Error" appears on my overhead DVD/Screen Combo Unit?
If incorrect codes are entered for more than 3 times, your Eurovox overhead DVD/Screen unit will show "Code Input Error" on the display.
Leave car key in the car and turn it to Accessories for approximated 1 hour, the overhead DVD/Screen unit will reset itself and shows"Security Input 1***" on the display.
Good luck... a FixYa rating would be great for my attention to your problem. Cheers mate
regards
Graeme
Mar 08, 2008 | Car Audio & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
79 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
