Question about RSQ MV333 3Disc CD Changer
When i put a disc in, the disc does not spin, then the machine checks all trays for a disc before displaying "no disc". i found no evidence of anything broken, yet it won't even spin a disc in any tray.would this be a problem with the laser?
  • 35 Answers
Probably the laser lens are dirty, damaged or need realignment. Take the unit to a good repair shop. The service is not much expensive. Good Luck.
Flavio/Brazil
Posted on Jul 28, 2010
Panasonic DMRES15 DVD Recorder disc not spinning
Troubleshooting Solution
1.Display Message " Please wait" Not
booted
2.DVD-Rom Two-Three times make noise but doesnt spinning
3. Doesn't
open tray, No video OUT
1.Bad Main Board VEP79117
2. Bad DVDROM
3. Bad Prosessor
PCB
Mar 16, 2013 | Panasonic DMRES15 DVD Recorder
The bobbin winder will not work
My bobbin winder worked great for a while. The last time I used it it worked fine. Today I got it out and it would not spin the bobbin to wind it. I got on a forum and they talked about the O Ring deteriorating. I took the machine apart and found no evidence. No melted rubber, shavings NOTHING. In fact that there was no evidence the O Ring had EVER been there. I looked in my husband;s stash and found several sizes until I found one that fit. I put it in the groove where it should had been and it is working great now.
Jul 06, 2012 | Brother CS-80
H02
The HO2 message means the disc is not spinning,it's not about the lens
or the laser.It is easy to take the lid off.Once you do that,plug it in,open the tray with the remote,put in a DVD,close the tray and then give the white plastic wheel on the top a gentle little nudge to get the disc spinning.
Jan 30, 2010 | Panasonic DVD-LS50 Portable DVD Player
Had one for years but now it does not even want to spin a disc the disc loads ok but jirks not spins and then the display says :-NG DISC?
This will require a good clean on the inside, POWER OFF then remove the cover clean the plastic rack with rubbing alcohol and cotton bud.
If the DVD won't spin due to trapping inside the tray you will never be able to read the DVD check to see if the tray will insert and eject usinf the button,
NOTE : never push the tray to close this can cause the tray to jump its guide dogs leg which is used to lift he head to the DVD after it has been inserted.
Dec 08, 2009 | Sony DVP-F21 DVD Player
Just spins
This sounds like a samsung drive, the laser is probably dead or on its way out or it could also be the small belt that is stretched and to weak to shut the drive properly, either way the machine will need to be stripped down and repaired.
we can get this back to normal for you just email us at www.fixmyconsole.co.uk
Feb 21, 2009 | Microsoft Xbox 360 Console
Sony hifi wont play cd's
Optical lens requires cleaning.
Please put cd cleaner in tray and check if it cleans dirt on lens. Still same problem, then unplug unit from AC outlet, take off top cover of hifi system and clean lens with good quality cotton bud. hope this will resolve problem.
Jan 26, 2009 | Audio Players & Recorders
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
DVD
I just fixed mine. Same scenario, with the loading and #1 displayed. The tray changer was jammed.
Take the cover off the unit and gently convince the changer to spin. It will go *crack* and then exhibit free-play. Turn the machine back on and voila it works.
I'm now watching Braveheart on 480p on 55"widescreen!!!!!
Wally
Oct 27, 2007 | Kenwood DV-605 Multi-disc DVD Player
Disc changer won't open
sometimes the timing cam that is just below the tray, it is a plastic bar with teeth along its edge will get out of sync with the tray, draw it to the opossite end and put the player back together and the players tray assembly will re sync itself...i hope this helps you
Jul 30, 2007 | Samsung HTQ45 System
RSQ MV333 3Disc CD Changer Logo
117 people viewed this question
Top RSQ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a RSQ Audio Player and Recorder Expert? Answer questions, earn points and help others
