Question about Brother DCP 115C All-In-One InkJet Printer
Printer not used for about 8 months i have replaced all ink,not printing properly no specific colour and very yellowish.what can i do?
  • jmac1962 Jul 28, 2010
    many thanks at least now i know i need new one.
  • 12,061 Answers
Unfortunately, I fear your printer may be beyond recovery, you see unless you especially prepare your inkjet for storage. If this isn't done, the old ink, dries inside the lines in the printer and it is this that stops it from going, and makes it very difficult to get it going again. usually they are not recoverable, one must strip down and clear all traces of ink from all tubes etc, it is a mission.
I think you will need a new printer.
Posted on Jul 28, 2010
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
Colours are printing in yellowish greens and does not look natural. What can I do? Thank you.
Replace the colour cartridge -- you are seeing "mixtures" of only TWO of the THREE "primary" colours.
Sep 15, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printer will print with almost no ink on page in colour or b/w
You have to have both the cartridge installed and then
Run a nozzle check to make sure the nozzles are clean. Try running a printer self-test to make sure the printer is running properly without using the computer.
Macintosh 9.x or earlier: Open the File menu and choose Print. Click the Ink icon. You'll see a window showing the ink remaining in each cartridge.
Macintosh OS X: Double-click the Applications folder on your hard drive. Double-click EPSON Printer Utility, select the C42 Series printer in the Printer List window and click OK. Then click the EPSON StatusMonitor button. You'll see a window showing the ink remaining in each cartridge
May 04, 2009 | Epson Stylus C42UX InkJet Printer
I replaced the black ink cartridge but I can't print
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 08, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Colour printing
If its a Canon printer try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 02, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have...
Think you may have killed your print head, but try this.
13. Start printing.
Jul 01, 2008 | Canon Office Equipment & Supplies
Red colour prints brown
Just replace the non genuine inks with proper Canon ones and then do about 4 full cleans, that should fix it. If not you will have to replace the printhead, which is usually caused by using non genuine ink. Good luck
May 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Brother DCP 115C All-In-One InkJet Printer Logo
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
