Question about Hotpoint Washing Machines
MY HOTPOINT WASHER WILL NOT SPIN, I CAN HEAR THE MOTOR AND IT ACTS LIKE IT WANTS TO - MODEL VBSR2080W1WW
  • 5,081 Answers
Could be the the little gear checks under the agitating cap , take a screw driver and pop the cap on the top of the agitater, and look at the 3 little plastic, catches, there is a gear there where it goes back and forth , and when it turns, thses little catches, connect, and make the agitater spin , thses can be replaced easy , and will save you a lot of money, let me know
Posted on Jul 28, 2010
  • sungaltan Jul 28, 2010
    THANKS - ILL CHECK THAT IN A WHILE . I USUALLY DONT DO LAUNDRY AFTER 4:30 IN THE A.M.
    HAVE A GREAT DAY -- TTL
    JODI VAN MAREN
  • sungaltan Aug 02, 2010
    I do not see three gears when i pop off the fabric softener top on the agitator. does the whole agitating tower come off from the bottom of the washer?
    thanks, jodi
    Brigadier General:
  • 3,917 Answers
Hi
Please check that lid switch. Start the machine to fill. Then open and then close the lid while it is filling. Does it stop filling when you open the lid? Next let it agitate and do the same thing. Does it stop agitating with the lid up? Next, put it in spin and try to open and close the lid.
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:SIY_WMSPIN
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
    OK MR. GURU ---- IT DID NOT STOP FILLING - DID STOP AGITATING , DRAINED AND IT DID SPIN.....AND STOPPED WHEN I OPENED IT AND CONTINUED WHEN CLOSED. BUT LET ME TELL YOU, FOR SOME REASON, WHEN WE MOVED IN THIS HOUSE, MY HUSBAND AND I BOTH WOULD FORGET TO CLOSE THE LID -- ALOT! SO I'M ON THE 3RD LOAD-- IT DID SPIN THE TWO FIRST TWO LOADS......I'M WAITING TO SEE IF IT WILL SPIN AGAIN.......AND WAITING.....OK, ITS SPINNING. DOES THAT MEAN THE LID SWITCH IS GOING OUT AND CAN I REPLACE IT MYSELF?
    WOULD LOVE TO BUY A NEW ONE, BUT HAVE A SON IN HIS THIRD YEAR OF COLLEGE.. AND WE DO HAVE A W/D AT MY TANNING SALON
    THANKS FOR YOUR HELP --- THIS IS AWESOME ---
    JODI
    Jul 28, 2010
    - OK MR. GURU ---- IT DID NOT STOP FILLING - DID STOP AGITATING , DRAINED AND IT DID SPIN.....AND STOPPED WHEN I OPENED IT AND CONTINUED WHEN CLOSED. BUT LET ME TELL YOU, FOR SOME REASON, WHEN WE MOVED IN THIS HOUSE, MY HUSBAND AND I BOTH WOULD FORGET TO CLOSE THE LID -- ALOT! SO I'M ON THE 3RD LOAD-- IT DID SPIN THE TWO FIRST TWO LOADS......I'M WAITING TO SEE IF IT WILL SPIN AGAIN.......AND WAITING.....OK, ITS SPINNING. DOES THAT MEAN THE LID SWITCH IS GOING OUT AND CAN I REPLACE IT MYSELF?
    JODI
Hotpoint washer won't spin or agitate
Jump the lid switch and see if it works, then you'll know it's the lid switch
May 16, 2017 | Washing Machines
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Wont emtry
can you hear the motor spinning.
May 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Set washer to just spin
Set timer dial to the final spin position,approx 8-40 position by clock time you will then hear the pump come on , and it will do just the last final spin.
The spin symbol is marked with a large squirl.
To get a copy of instructions go to www.hotpoint.co.uk
On the list click on Manuals-user guides-handbooks
In the search box enter your washer model number, and download the instructions.
Plz rate my solution.
Thanks
Jan 24, 2009 | Washing Machines
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Motor runs, but no spin.
You don't list model number so this will be a bit generic for Hotpoint top loader. If the motor spins but the belt is not moving: With power off, manually turn the large pulley the belt goes around, just a revolution is enough. Spin is CCW, but you may have to try CW (agitation). Now set turn the washer on spin again. This may unlock your transmission, but unfortunately is usually only a temporary solution. If the machine was manufactured prior to 1-1-06 and still under five years old, the transmission may still be covered under warranty. Check the back pages of your owner's manual. (labor would not be covered) If too old / not covered, I'd invest in a new front loading washer. The LG's are #1 rated in Consumer Reports and are direct drive (with a 7 year warranty on the motor) so there is no transmission, clutch, belt, or pulleys. You don't have to get the top of the line model, all LG's are direct drive and very good. Other front load machines, although not DD, will also use much less water than your hotpoint and spin out twice as fast or more, reducing dry time and dry cost. I know this wasn't what you really wanted to hear (bad news), so don't bother rating this "solution". (don't want my rating to go down just because I told someone bad news about there machine.)
Oct 05, 2008 | GE Hotpoint 2.7 cu. ft. Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
