Question about Linksys Wireless-G WRT54G Router
Hi I am using Nokia Siemens c2110 modem. how to configure autodialup in this to connect to internet for airtel broadband
3 Suggested Answers
kakee
  • 1269 Answers
SOURCE: Unable to access advanced console of siemens c2110 adsl modem
If you device is just a Modem, there's no advance settings because it only acts as modem. It doesn't have a router function. Only devices with router function have that advance menu.
Posted on Apr 27, 2009
  • 211 Answers
SOURCE: How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Posted on Jan 10, 2010
Dataone broadband siemens adsl c2110 modem driver
Am I correct in asking you whether you are using a bsnl broadband....???? If so you don't need modem drivers. All you have to do is configure a broadband connection from your network connection wizard with your username and password. Good Luck
Jan 08, 2011 | Computers & Internet
Download speed
1.connect through the lan port
2. keep ip as automatic (from lan properties > tcp/ip)
3. open modem configuration page by typing http://192.168.1.1 in the address bar of your web browser.
4. create a bridge or pppoe setting using vci = 0 and vpi = 35
5. if u choose bridge mode then create a dial up broadband connection from new connection wizard
6. give the port settings over there in modem and use the same ports in your torrent client.
7. You are done . and you will see the speed increases becoz of DHT enabling freely and you will get downloads bypassing the torent server tooo... :-)
Hope it helps to you. Thanks.
Dec 18, 2008 | Computers & Internet
Restrict Internet Access for certain users
give each person a specific code and if that code is not correct , a notice will come up saying --you are not authorized to use the net refer to administrator
It is a simple procedure for an it specialist programmer
Jul 30, 2017 | Computers & Internet
Nokia siemens ADSL Modem c2110 USB Driver
How can i download usb driver form ADSL Modem c2110 i want to down load the siemens c2110 usb modem driver.Please help me.
Sep 29, 2008 | Computers & Internet
USB Driver for Siemens C2110 modem
use an ethernet connection to connect to PC instead of USB
the default IP is 192.168.1.1 then use internet explorer to setup it up
Jul 06, 2008 | Siemens (120-5830-001) Modem
Nokia siemens adsl c2110 modem not installed
i have dataone siemens c2110 modem,this is new modem,when this installed the pc and showing this command"the modem could not connect in your pc,and not dectect"i have line properly attached in pc to modem.please help me
Jun 05, 2008 | Computers & Internet
How to connect Siemens broadband modem over ethernet port like HUB/Switch
First of all connect with the cable computer and your ethernetcard and phoneline to your modem c2110 and then turn on the power of your modem,then type the address 192.168.1.1 at the explorer bar.Their you will find a pop up requesting you to enter username and password,enter the admin as username and admin as the password.Then proceed and just click on configuration given on the left side of the page,after clicking three subheadings you will find first local network the other internet and the third one DSl home, then just click on the internet their you will find several things to edit but you only click on the edit button infront of where "pppoe_0_35" is written, after that just do next and next untill you will find at one place Broadbandusername and Broadbandpassword, their u enter the username and password provided by the BSNL, after that click on the APPLY button,and wait for few seconds. and then close the window,and now enjoy surfing internet.
Mar 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens ADSL Modem(model- C2110)
siemens c 2110 modem 3 lights flasing continously what to do
Mar 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Modem Driver
I lost my driver CD. Is there any way i can download2.gif the driver for modem2.gif C2110
Thanks,
Gunjan
Dec 18, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Linksys Wireless-G WRT54G Router Logo
232 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
