Question about Kenmore Oasis HE 27082 Top Load Washer
The lid is locked on my kenmore oasis washer
During a heavy load the cycle it stopped & I can't get the lid to unlock
    Problem Solver:
  • 7 Answers
Unplug the washer first. How to open the service lid. Latches are approx 4" in from corners in front (where the little crack is below the lid) insert a putty knife, pushing in on the latches and pull up as it gives. Hold onto the side you've released and pop the oter side and lift up.
Now you will be able to see the lid lock; center front from underneath. Use a 1/4" nutdriver and remove the latch.
Now as far as I know, pn:8563937 was replaced with: W10059230 Bought mine from www.midwestapplianceparts.com.
Install is simple; 3 screws (1/4") behind the back panel will allow you to access the plug. Just feed the old one out and the new one in.
Posted on Aug 03, 2010
How to by pass the lid lock switch on a Kenmore elite Oasis HE washmachine
Not a real good idea except under emergency situations, as the lid lock is a safety switch to prevent access to the washer during spin cycles when the drum is operating at high speed and you don't want foreign objects (like hands) coming into contact with a high speed rotating drum or its contents. If you have the unit open enough to cut the wires, you had enough access to replace the switch, which you can get at SearsPartsDirect.com or any Sears Service Center in your area. If you are hell-bent on operating the machine in an unsafe condition, just connect the bare ends of the wires with a wire nut, which will perform the same circuit connection as the closed switch. Tape the connected wires away from any moving parts, don't let any bare wire come in contact with any metal and keep the lid closed during all parts of the wash, rinse and spin cycles.
Jul 25, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Lid does not lock will not take cycle instructions
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) from www.midwestapplianceparts.com
Jul 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Power comes on and all lights come on, but the washer will not start the wash cycle. After the start button is pushed the lid lock will not lock.
That is why the washer won't start. Replace the lid lock. It is there to stop anyone from putting their hands inside of washer when it ia agitating, by stopping power to the motor.DO NOT try ANY attempts to mmake it work!!!! Injury may result
Feb 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
Jan 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The lid lock is broken, can it be unhooked, machine will not engage with lid unlocked.
Following is the Whirlpool service manual for their Cabrio washer, basically the same as the Kenmore Oasis.
It has a troubleshooting section as well as diagrams and instructions concerning the Lid Lock.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Oct 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Code ul appears shortly after start up
I think ul is unbalanced load, not unlocked lid.
Jul 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
No display on Kenmore Oasis
there should be a repair manual inside the machine. If you use a screw driver in the front to open the top of the machine the manual should be on the inside of the front panel.
Oct 13, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
241 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
