I tried to turn on my hp laptop. At first it flickered and and then I took the battery out and then I put it back in and turned on my laptop again. but the screen was black. Now it remains black.
  • 358 Answers
Even though a lot of things might have gone wrong and caused this,
But I will try and tell you some troubleshooting steps that you can try.
First of all, disconnect your battery from back of the laptop, and try to power your laptop without the battery there, if it powers up, then just get a new
battery.
Second, get a screw-driver, remove all the RAM(memory sticks) at the back of it, clean their interface with an eraser, and try to power it on first without
them, then replace them back and power it on.
Alternatively,
Remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
Also from what you have just said, I suspect that your hard drive is likely to be corrupt, or having a bad sector on it.
To be sure of this, disconnect your hard drive from the laptop, and power it up without connecting the hard drive, if it boots up to the point where it says:
"Operating System Not Found" or "No Bootable Device Found", then that shows that your hard drive needs replacement
Kindly Let me know how it goes.
Hope this helps.
Posted on Jul 29, 2010
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
No display on hp 6345s laptop
Try to turn off your system. Then remove the cables and battery on the laptop. Then press and hold the power button for 8 secs. Then, reinsert the cables and battery on the laptop. Then, press the power button to turn on the laptop. If the HDD light flickers continuously, then the problem is on the Hard Drive. One way of resolving it is to Re-Seat the Hard Drive. If you know how to tear down the system, here's how. Turn off the laptop, remove the cables and battery at the back. Remove the screws located at the corners of it. Then remove and reinsert back the Hard Drive. If it still fails, contact ACER to immediately replace the Hard Drive. If you don't know how to tear down the laptop, then call ACER also for repair....
Jul 19, 2010 | Acer Aspire 9300 Notebook
My HP Pavilon Zed 145 wont start up. Keep turning
Try to run on AC power with battery removed. If still problem persists, then its time for repairs!!
Sep 06, 2009 | HP Computers & Internet
Hp not turning on laptop
you haven't got the TFT cable plugged in correctly
Jul 25, 2009 | Computers & Internet
BB screen is flickering on & off then turned black after in water
If your BlackBerry gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Jun 12, 2009 | RIM BlackBerry Pearl 8100
HP Pavilion laptop went black as I was surfing
hi,
If after refixing the battery also the issue is not resolved so try to tap num lock when restarting the machine.
if no power is there issue might be related to motherboard.
if taping the num lock glows the lED of numlock means RAm is faulty.
Feb 09, 2009 | HP Pavilion tx2500z Notebook
My HP Pavilion dv6000 won't turn on
if no one led blink and it show no power then remove battery then refix it.
Jan 20, 2009 | HP Pavilion dv9000z Notebook
My hp pavilion dv6000 laptop does not turn on, the blue buttons light up, but the screen stays off
Try it without the rechargable battery connected sometimes the battery shorts and causes problems.
Do you have FN[function] keys at the left side. touch FN key with something else and see if screen comes back.Sometimes you can turn off the screen to send it to the back connected monitor.Connect (extra if you have) an external monitor to the back (vga) connector.If that shows, then you have to ""flutzz" with the FN(function) & F1-F12 keys
Nov 28, 2008 | Computers & Internet
It won't turn on,
change the other battery work's if the work then you battery work goes
Jun 13, 2008 | HP Computers & Internet
Laptop just went blank...cannot power up or turn on
try by resiting the ram, if the problem persits than your display adapter is having problem
May 19, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
44 people viewed this question
Alun Cox
David Payne
David Payne
