Question about Foundry Networks FastIron® Edge X424-POE-PREM 28-Port Gigabit Ethernet Switch (FESX424-POE-PREM)
Please tell me if there's any default username and password for FastIron edge X424 to login into the admin console.
Help me with my wep key please
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Belkin F5D8236-4 Router
Reset password of DGS3627 from console
Sep 07, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a trendnet tew-625brp, i just opened it, i can connect to it perfectly by cable howeve i want to set it up wirelessly, when i go to 192.168.10.1, i type in admin for username and password, and it...
You must complete the setup with a wired connection. Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Sep 07, 2011 | Computers & Internet
I dont know where to find the password can you help me ?
By default, the CLI does not require passwords. However, if someone has configured a password for the device but the password has been lost, you can regain super-user access to the device using the following procedure.
1) Start a CLI session over the serial interface to the Brocade device.
2) Reboot the device.
3) While the system is booting, before the initial system prompt appears, enter b to enter the boot monitor mode.
4) Enter no password at the prompt.
5)Enter boot system flash primary at the prompt. This command causes the device to bypass the system password check.
6) After the console prompt reappears, assign a new password.
Feb 07, 2011 | Foundry Networks FastIron® Edge...
I'm trying to change some of the settings on my Belkin wireless router for a gaming console so I typed in 192.168.0.1 to the internet and chose "connection configuration" and it says I need an...
1.The router does not ship with a password, so just click Submit.
2.And if it doesn't work then try this
click on login
enter username: MiniAP
password: Admin
3.If suppose the above also dint work then
renter username: Admin
password: Admin
I hope this will solve your problem
Jan 08, 2011 | Computers & Internet
We have foundry edgeiron 2402cf switch and forget my username and password , what i shoud be made ?
Please follow the steps below to reset the password
1. Power Off and Power ON the switch
2. Immediately enter 'b' to go to the boot monitor mode
3. Do not Enter any password in boot monitor mode.
4. Enter boot system flash primary
5. You will be getting a prompt as 'FastIron>'
Please set the new password as below:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password admin
FastIron(config)# write memory
Your new password is set now as 'admin'
Best Regards
Nov 10, 2010 | Foundry Networks Foundry EdgeIron 2402CF...
Cant login never had username or password if i did i forgot
Depending on which revision you have there are two possibilities
Default Username is: admin
Default Password is: password
or
Default Password is: admin
If neither of these work - you may have setup a new username and password and forgot - on the router you will see a reset point - reset the router to factory defaults and the username and passwords above will now work.
If this helped you then please help me and vote kindly, thank you.
Oct 14, 2009 | NetGear WGR614 Router
Default login information on a 6381-a3-200
first write 192.168.1.1 on address bar a login window will apear write user name and password admin
Jul 25, 2008 | Zhone Paradyne 6388-A1-200 Router
Wireless network
Default login combinations are usually; Username: admin Password: {blank} Username: admin Password: admin Username: admin Password: pass Username: admin Password: 1234 Username: {blank} Password: admin Which make/model is your router?
Jul 03, 2008 | Computers & Internet
Foundry Networks FastIron® Edge X424-POE-PREM 28-Port Gigabit Ethernet Switch (FESX424-POE-PREM) Logo
116 people viewed this question
Top Foundry Networks Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Foundry Networks Computer and Internet Expert? Answer questions, earn points and help others
