Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Replacement bulb only lights for a day and then burns out again
    President:
  • 3,197 Answers
There are heavy duty/rough service bulbs you can buy at the hardware store that are made to withstand the vibrations. You might also try unplugging the opener and removing the light bulb. Use a screwdriver to reach down to the center contact in the light socket and pull out. That will increase the tension on the bulb somewhat.
Posted on Jul 28, 2010
Have a brand new jonway 50cc 15 miles blew bulb whats wrong
Occasionally bulbs will fail for no reason. Replace the bulb and try again. If it fails again, then you likely have a problem.
May 23, 2016 | Jonway Motorcycles
How do I pick a right bulb for Christmas tree and string lights? Some are 2.5V some 3.5V some 5V... Some say 2.5-3.5v. I replaced some burned bulbs with generic 2.5-3.5V bulbs from stores and they are
Now this is one I ask myself. Why Dont the same people who sell a certain brand of lights sell a pack of replacement bulbs of the same brand? Most lights come with a few replacement bulbs but it just seams easier to use and old set that match others I have for "spares bulbs" and buy a new set for a tree or bush or an item not next to other older set(s). Otherwise if you still have a bulb one can check the ohms with a multi-meter and compare the with another. Voltage would have to match and then would have to look for some bulb with the closest ohm. Like I said. Why not sell bulbs for the lights you have sold. Seems the cheap ones are the only ones that are more standard then bigger names cause they just seem to change (improve) their design. Good luck.
Nov 30, 2014 | Christmas Lights Etc Toys
I keep replacing the head lights only to have them burn out again.
make sure you dont touch the bulb with your bare fingers. touching them will make them burn out within days or weeks. use something clean, a napkin, paper towel, or similar. avoid touching the bulbs.
Jan 18, 2011 | 1989 Ford Tempo
A few weeks ago I noticed that the drivers head light had burned out. I replaced it, but never checked to see if it was fixed. A few nights later I noticed it was just barely burning again. I figured I...
This is a poor ground connection to the bulb or to the unit. Since the main battery + is coming in the bulb glows but it idoes not receive a good negative which has to come from the ground of the car. So have the ground wires taken out , cleaned and fixed back.
Nov 01, 2010 | 2000 Volkswagen Jetta TDI
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    HEADLIGHT BULB KEEP BURNING OUT ON MY BENZ..2002 C CLASS
    Try to put a relay on every bulb to prevent burning, and also check the bulb socket make sure it is not loose.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
    Jun 09, 2009 | 2001 Mercedes-Benz C-Class
    One surface light bulb on GE Profile microwave keeps burning out
    I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
    Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    All light bulbs burn out again and again, how to fix this.
    Check the battery voltage with the engine running at idle and at 2000 RPM. Voltage should not exceed 13.6 volts. To burn out bulbs the alternator would have to run at 15 + volts to fatigue bulbs. If the voltage is high, investigate charging system.
    Let me know.
    Regards,
    Feb 14, 2009 | 2001 Chevrolet Cavalier
    START AND SHUTDOWN
    Hello Mr. Bond.
    I believe that you have a rear projection TV where the light from
    a powerful halogen light bulb is focused onto a micro-prism
    viewing screen through a Liquid Crystal Video Chip.
    The light-bulbs have a finite life, degrade with time and eventually
    burn out. It is likely that you have a burned out light bulb.
    Replacement light bulbs range from about $150 to $250 from
    the dealer, depending on the exact model.
    The bulbs are somewhat cheaper by mail order from the Internet,
    if you can wait that long. Also, some bulbs are available without
    the integral mounting bracket, further reducing the cost, but
    skilled hands and careful handling is required.
    Never touch the glass of a TV light bulb with your bare fingers.
    The bulb runs very hot, and residual sweat from your fingers
    may cause th bulb to crack and explode.
    (use gentle white cloth gloves when handling the new bulb.
    I believe that bulb just burned out on its own, and this has
    nothing to do with your attempt to connect a DVD player.
    On my TV (Sony 60"), a flashing green light indicates a
    normal power-up/ bulb warm-up cycle. If the bulb fails to
    respond, the TV will detect a bad bulb and shut off again.
    Apr 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    208 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
