Question about Ricoh Aficio CL3500N Laser Printer
Ricoh aficio 1515 printing faded images on one side. Just replaced the drum / toner / hot roller
Provavelmente o problema ? na porta lateral, no rolo de transfer?ncia, aquele rolinho preto no meio da tampa, ao tirar ele tem uma mola em cada lado, o lado da c?pia fraca est? com a mola com pouca press?o, estique um pouco a mola e coloque-a de volta, deve resolver...
Posted on Aug 06, 2010
Part of printed copy is washed out ricoh aficio sp c210sf
Seems its fuser assembly fault.
Fuser assembly is a part to fix toner image permenentely with the help of hot rollers on media. The temparature varie depends on model, in case the temparature not reachess specified level you may get image fixation problem, the same what you are facing. Replace fuser assembly.
Oct 02, 2014 | Ricoh Aficio SP-C210SF Printer
Ricoh aficio 2075
R u using original toner? if no, replace ori. if yes, r the hot roller in the fuser hot enough? is there any gap between hot roller and pressure roller? toner smear can only be caused by non ori toner or faulty fuser unit. Faulty developer can cause sandy print out
Mar 22, 2014 | Ricoh Office Equipment & Supplies
We have Ricoh Aficio 1018 , machine functions , gives print without the matter printed
Sounds like a bad photoconductor unit (PCU), or problem with the transfer roller which is mouned inside the right side door. The PCU consists of 2 main sections; the development unit, with developer ang mag roll (on the bottom) and drum, with charge roller and cleaning blade (on the top). If the gears that turn the mag roll go bad, toner will not be applied to the charged drum. If the transfer roller is missing or not being charged the image will not be transferred to the paper. Check the connector from the copier to the right side door and the leaf springs that carry the charge from that wire and contact the transfer roller.
Sep 07, 2012 | Ricoh Aficio 1018 Printer
Ricoh aficio 1515 printing faded images on one side. Just replaced the drum / toner / hot roller. Same issue when printing and copying What else could cause the problem?
Could be one of a few things:
Most likely is the transfer roller. If it's dirty or old and not applying enough charge, it may not be pulling all the toner away from the drum. Replacing the transfer roller is easy if you can get a new one.
Are you sure you have the correct toner? The wrong toner can definitely cause copy quality problems.
If the springs that hold the press roller against the hot roller are not properly in place (or if they have started to lose tension) the toner won't be fully fused onto the paper.
I'd start with the transfer roller (black roller that sits opposite the drum on the right side door) first -- it's the most likely culprit.
Jun 17, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Black prints 1" either side of page. middle fades to nothing.
clean the paper path rollers. usually if toner cartridges are refilled type they are overfull and spill toner on paper path.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Ricoh Aficio CL3500N Laser Printer
RICOH AFICIO 1515 when printing/copying, comes out with a blured section on the left side (about 1.5 inces wide). I just replaced the drum. Same issue was with the old drum. What else could cause this...
Take you drumback out and lookinto the machine with a flashlight.
There should be a piece of glass that isolates the laser from the rest of the machine, check for dust or toner. Clean if necessary.
Jan 22, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
RICOH AFICIO 401 COPIER- COPIES FADED ON ONE SIDE
Hello sir; You have to replace drum and developer meanwhile you have to clean up image roller, then it will take care the problem.
Nov 06, 2009 | Ricoh Aficio 450 Copier
Faded Printing
gfkhdsfagljsafsadfdsafdsa
Aug 05, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
260 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
