Question about Linksys EtherFast Cable/DSL Router
Linksys wired router model BEFSR41 no internet
I have been using this for quite some time without any problems and all of sudden I cannot get any internet connection. My internet server Cox says it is my router. When I disconnect my router entirely and hooked up internet cable directly from my desktop CPU to my modem it works fine. The reason I was using a router was to wire my internet cable via the router for my laptop at the same time being connected with my desktop.
    Top Expert:
  • Linksys Master
  • 45,065 Answers
Believe Cox
Posted on Jul 13, 2017
  • 34 Answers
SOURCE: WRT54GX2 Wireless-G disrupts both laptop and desktop internet connections
it might be because of interference...no issues dont worry about that...
JUst follow these steps and the issue will be resolved....
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
router)
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights lit.now turn on the router and wait
till the power light is solid..open the internet Explorer it should work..
STEPS FOR WIRELESS CONFIGURATION
6,open internet Explorer and in the address bar..enter as 192.168.1.1..it will prompt for a
user name and password..leave the user name blank and the password will be admin.
7,
U can see the option WIRELESS in the black bar..click on wireless..
Wireless network mode should be "Mixed".wireless network name can be ur first name or
anyother name.select the channel as 11 and the SSid broad cast should be Enabled.click on
save settings.it will say like "Settings are successful"click continue.
8,to set the password for ur wireless network...below wireless tab in the black bar..u will
find a blue bar which says "wireless security".click on "wireless security". Security mode
should be "WEP"..Default transmit key should be 1.wep encryption should be 64
bits..passphrase should be empty..in the key 1 box enter ur 10 digit telephone number(ur
telephone number will be ur password for the wireless connection)click save settings and
continue..
9,
now in the laptop check whether the wireless switch is turned on...u can find ur wireless
signal..while connecting it will prompt for a password.enter ur telephone number there..
u will be connected to the internet..
Posted on Jun 03, 2008
florenn
  • 174 Answers
SOURCE: cant get to internet thru linksys etherfast cable/dsl router
i you restart you devices, modem and router...
first turn off the modem and then the router and last will be the computer
second if you will turn the devices on...
first turn on the modem,wait until the dsl light becomes solid
second turn on the router,wait for a minute and
third turn on the computer.
check the wireless settings for your router and save changes
next, try to check wireless connection by disabling the local area connection (LAC)
Posted on Nov 09, 2008
SOURCE: Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Posted on Mar 13, 2009
rahul26485
  • 611 Answers
SOURCE: Connectin a linksys Befsr41 wired router to a Motorola 2210 modem
do one thing change the ip address of the LAN in the 192.168.2.1 in the router then you get it after that configuration you done right ok
Posted on Apr 14, 2009
  • 55 Answers
SOURCE: Problem with VPNand Linksys router WRT150N
If that is the case you may forward ports on the router for VPN connection, try to open 47, 500 and 1723 all TCP and UDP protocol.
Here's what you need to do, check the IP address of the computer where you have the VPN software,
here's how:
click start> run> type cmd> hit okay
on the black screen put in ipconfig and check the IP address there,
> when you get the IP address then we can enable port forwarding on the router
> open IE on the working computer on the address bar, type 192.168.1.1
> nothing for username and password is admin in lower case
> then click on the applications and gaming tab on the router,
> and from there, example of how to field that in is like this,
> for aaplication name - VPN1
> for port it is 47 to 47
> for protocol it is BOTH
> for IP address ex. 192.168.1.XX - 192.168.1.100
> then check enable, do the same thing for the rest of the port.
> save the settings and try it again after.
> if it is still nothing, you may connect the computer that has the VPN connection directly to the modem and check if you will be able to connect via VPN
i'll wait for your response, thank you and have a nice day!
Posted on Jul 15, 2009
I have been running a Linksys BEFSR41 version 2 wired router for over 5 years without any problems. My wife is a teacher and her school p[urchased new laptops recently so I decided to go wireless. Got on...
I think the most likely problem is that both routers are using different IP address ranges and won't allow data to pass between them.
I suggest you use only the Linksys wireless router.
Nov 17, 2010 | Linksys Wireless-G WRT54GS Router...
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
hi,
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Router suddenly dropped connection. Have been using this same router without issue for about 8 years now (Linksys BEFSR41 router). When I tried resetting the router and plugged the power back in, the power...
If the power light keeps blinking it means that the router has reached its end point or else you have short circuited the board, or the router is reached up to the maximum whereby it has totally failed. The best would be to replace that router now or try to use a software named tftp to get into the router interface if it is possible then upgrade the firmware/ You can get tftp by searching in google.
Jan 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Setup and confifuration of my linksys befsr41 ver 2 router
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Dec 17, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Cable/DSL Router model BEFSR4141
Since you did not include the type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Oct 25, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Lynksys BEFSR41 hookup
To hook up your lynksys router plug your internet connection wire in the back of the router where it says linksys then run another cable from the slot one to your computer, when you first get your router your username and password will be admin type your IP address into your internets browser window and use your username and password to log onto your linksys router, choose your router settings and there you have it,
Good luck
Chris
Feb 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys EtherFast Cable/DSL Router Logo
126 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
