Question about Refrigerators
The cooling unit in my dometic rm 2201 needs to be replaced is there anyone in Canada or must I go to the usa
  • 9 Answers
SOURCE: dometic RM 2800
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
SOURCE: How many amps does a unit like this use?
According to the label (inside the hinge of the main door), it's 2.7 amps when running on 110 volts. It shows blank for running on 12 volts. However, with the anti-humidity switch on, it can use enough current to drain your battery. I was concerned about the battery draw when running the fridge on 12 volts, because the dealer told me it defrosts itself every 72 hours. Something has to control this, and probably uses some power.
Posted on Jul 25, 2009
  • 98 Answers
SOURCE: Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Posted on Sep 25, 2009
Testimonial: "Worked!!!"
motor1258
  • 6674 Answers
SOURCE: I have a Dometic Rm 2862 2-way about five years old.
Ammonia smell means cooling unit is done. Just double check on dometic site in case of any recalls that may apply. (dometicusa.com)
Posted on May 27, 2010
Dometic rm 2652 RB feg no cooling, checked all fuses, and lights work, but no cooling
check fusible links if ok unplug thermistor let run if cold replace if not possible bad control board or cooling unit see if chimney hot if hot bad cooling unit
Jul 18, 2018 | Dometic Refrigerators
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
Recharging my dometic rm 2611
closed system replace cooling unit
Jan 17, 2014 | Dometic RM2620 Refrigerator
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
May 24, 2010 | Dometic RM2852 Refrigerator
Dometic RM 2800 Refrigerator will not cool. freezer is some cool. this is on LP gas
Jul 12, 2009 | Dometic Refrigerators
Refrigerators Logo
194 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
