Question about JVC GR-AX230 Camcorder
I can't see anything through the viewfinder.only the clock shows.
There is something wrong with my Nikon D3000. It turns on but doesn't show anything on the screen and when I look through the lens it's shows a grainy dark film. It can't be the lense because I...
There seems to be two separate issues here. I'm going to assume you have a charged battery pack in the camera.
First, the screen. Turn the camera on. Do you see the menu when you press the MENU button? Does the shooting info show when you press the Info button? Can you see previously taken photos when you press the Playback button? If none of those show up then something is wrong with the screen (or the battery is dead).
Second, the viewfinder. First, make sure the viewfinder in the back is clean. Now turn the camera on and look through the viewfinder. Do you see the eleven focus marks? Do you see the info at the bottom? Now turn the camera off and remove the lens. Don't touch anything inside the camera! Do you see a mirror at a 45-degree angle? Is it clean? Look at the focusing screen above the mirror. Is it clean? Now look through the viewfinder and point the camera out a window. Do you see a more-or-less white blob, or the same grainy dark film?
Apr 11, 2013 | Cameras
The viewfinder on my Panasonic PV-DV200 needs to be cleaned. I have the instruction manual but I cannot get it to turn the 1/8 turn recommended to remove
Hi, My PV-DV200's viewfinder needed cleaned too. Try, try and try again. The entire viewfinder assembly will turn, but if it's never been removed before, it will be on extremely tight. My viewfinder has a small notch at about 1 'o' clock on top. That notch needs to be turned to about 11 'o' clock. Once there, the viewfinder slips off easily. It will come off much easier from then on.
However, simply cleaning the removed viewfinder may not be enough. You may also need to remove the two small screws on the underside of the piece that's still attached to the camera in order to get inside there and clean that too. I removed the small rectangular glass and cleaned that and behind there as well. I used a Rayban cloth (needs to be lint-free) and some Plexus, along with a dull pencil in order to get everything cleaned all along the sides of each lens.
Just double check and make sure all parts of the viewfinder are clean by slipping everything back into place prior to screwing it all back on. This will save you some time because you will probably not get everything cleaned on your first attempt.
Hope this helps!
Nov 16, 2011 | Panasonic PV-DV200 Mini DV Digital...
ViviCam
Do you have a viewfinder and a screen? The screen won;t show anything if you have the viewfinder turned on.
Jun 18, 2008 | Vivitar ViviCam 5100 Digital Camera
My viewfinder does not work
Sounds like your LCD is cracked. You can get it replaced for $89.95 at darntoothysam.com.
Mar 08, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
JVC GR-AX230 Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
