Indesit washer-dryer wd125 manual
Hi ive just bought my indesit washer-dryer wd125 from ebay and as i dont know how to use it i need to know how to get a manual for it free thank you
I've been looking for these instructions and have just stumbled across them . Just inside the door there should be a barcode. On the top right check the model no. mine is WD 12S, despite the model no on the outside being WD125.
If so, look here http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WD12S.pdf
ATB
The Mighty Lev
Posted on May 24, 2009
I need user manual for indesit wi25
Type your washing machine name into the Google search box and scroll down the list of 'hits'. You'll see your washing machine instruction booklet offered for free as a PDF which you can download in a couple of seconds.
Mar 09, 2013 | Indesit W 123 Front Load Washer
I'm looking for a user's manual for the Indesit washer/dryer combo WIDL 106 model. Can you help? Thanks.
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Oct 08, 2011 | Indesit W 123 Front Load Washer
Indesit WD125 washer dryer when not in usee water leaks into drum
The inlet solenoid valve need replacement. It is worn out. When not in use the solenoid valve remains closed & only opens when the machine needs water.
Aug 16, 2011 | Washing Machines
Indesit wd125 - everything works but the dryer doesnt get hot - wont dry
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';
Jul 19, 2011 | Indesit Dryers
INDESIT WIDXL126 IS IT A WASHER/DRYER IT WAS IN THE HOUSE WHEN I RENTED IT .THANK YOU.
WIDL is! Washer Dryer so I would expect that you have the 'Xtra' version!
Methinks you could do with a manual anyway but unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 26, 2011 | Indesit Washing Machines
Washer instructions need manual
eBay is your best bet.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit Washer/Dryer WD125 wont take conditioner
sounds as tho may not be draining. have you checked the filter? also check for foreign objects in the pump impellor
Apr 27, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
1,757 people viewed this question
Top Washing Machines Experts
