Question about Saws
I purchased a Used Delta table saw model 36-441.The previous owner had built a box around the motor to prevent dust and to reduce noise.the problem is that I can't set the saw to an angle without moving box.while in a hurry I forgot about the box and cranked *** the bevel knob trying to set a bevel. My blade alignment is now totally fowled up and I cant set a bevel more than a few degrees past 90. I have loosen the trunnions to re-adjustbut still no luck..please help
protek480
  • 1723 Answers
SOURCE: I have an older Delta Contractors Table Saw but no
Go here:
http://powertool.manualsonline.com/manuals/mfg/delta/delta_saw_product_list.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 09, 2009
desertrat144
  • 22 Answers
SOURCE: I recently bought a Delta table saw model # 36
The answers are simple, but a pain. For solution by internet try Delta's homepage, most manufacturer's have manuals online that you can download or request ($); try e-manuals.com they are hit and miss though. Now the painful part, check a Delta dealer or one of he box-stores that handle Delta, talk with the clerk, ask if they can burn off a copy or relevant parts, or if can't see if they will escort you to the store's copy machine ($$) and have at it. Not the best of options but...
Posted on Aug 21, 2009
Testimonial: "Great ideas, the most help I have received and I will follow up on your suggestions and let you know how I made out. Thanks a million Dale Egan"
  • 8404 Answers
SOURCE: my delta 36-650 table saw 1.5hp motor dims lights
If you didnt replace your switch ... do so now. If you did replace the switch, check your work
Posted on Oct 25, 2009
SOURCE: Have a Skil #3305-01 table saw. Need to set blade
I have the same problem - what a terrible instruction and what a terrible setup. I bought this table for a specific job and spent considerable time trying to figure it out - then gave up. Wished i didn't buy it...
Did anyone figure this out?
Posted on Dec 27, 2009
  • 1388 Answers
SOURCE: Model 34-670 type 1 Delta
Aligning your tablesaw's trunnions to the table surface can be quite difficult to explain without graphic. Instead of quessing where the shims were please take a look at the following web address for a serious look at alignment.
http://books.google.com/books?id=s_YDAAAAMBAJ&pg=PA32&lpg=PA32&dq=add+shims+to+trunnion&source=bl&ots=B1A9eztgW_&sig=vFNUkFMjOcYKbnugG_0Ufo2QdmY&hl=en&ei=wJp5TKW1EMOclgf8qpy0Cg&sa=X&oi=book_result&ct=result&resnum=2&ved=0CB0Q6AEwAQ#v=onepage&q=add%20shims%20to%20trunnion&f=false
Posted on Aug 28, 2010
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
Table saw
I had a similar problem with my table saw. It would not come on. I unplugged it and cleaned out the on/off switch...it had saw dust in it that was preventing it from contacting and coming on. You might want to try this.
May 14, 2010 | Saws
I am not having much luck with blade alignment on my delta model 36-650 table saw. I have all the factory components that the saw came with. The 10 inch blade rubs on the table insert on the far right...
Check that the washers on the motor shaft are positioned properly. I believe the washers are dish shaped one should be on each side of the blade with the wide shoulder aginst the blade. Check this. Also if you go to Deltaportercable.com you can get an owners manuel for free on line. If this was helpful, please leave feedback.
Thanks, Snugglepants
Nov 02, 2009 | Delta Saws
Looking for a source for a 36-600 manual.
got it. go to Dewaltservicenet.com and in the middle of the page at the bottom under manual type in your number exactly as you have it and you can download the manual, it is 29 pages long if I have helped you with your request would you please rate this response accordingly and thank you.
Oct 30, 2009 | Saws
I have recently purchased used powermatic 66 Table
That is the current setting for a motor-starter which is an overcurrent sensor. This is a circuit breaker like device that usually has a heater coil that opens a contact which cuts the power to the relay that powers the motor to prevent overload damage to the motor.
The dial is in AMPS and should be set just slightly higher than the nameplate amp rating for the motor.
Oct 24, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
We just purchased a previously owned Ryobi table
Try the internet Quite often can find pdf downloadable manuals for most things
Oct 22, 2009 | Saws
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Motor not working on Delta table saw: I just got a used Delta table saw for free, the previous owner said the motor wasn't working. I wonder if it could just be a switch... how could I check that? I also...
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Apr 16, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Need owner's manual for used Unisaw 36-812
You can download one from the Dewalt service center. Click on this link and choose the saw that most closely matches your own:
http://www.dewaltservicenet.com/Products/ProductManual.aspx?q=36-812
If you found this link to be helpful, please rate this response so I can become a trusted advisor. Enjoy your new saw!
Mar 21, 2009 | Delta Saws
Saws Logo
574 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
