The screen on my digital thermostat went blank.
  • 121 Answers
That is usually an indication that the batteries have failed (inside). It is also helpful to turn off and then on the power to the furnace (to reset). ...most states require a switch on the furnace, or use the fuse.
Posted on Apr 24, 2008
What to do when an 8022c wall thermostat screen goes blank - no numbers, just the lines dividing the three areas? Pushing reset does nothing.
Pop the cover off and check the battery. Replace if necessary. If it still doesn't work trip the main breaker for the ac unit off wait 1 minute and turn back on. If it still does not work then you have a more technical proble. Could be a bad thermostat or control board in the ac unit.
Jul 03, 2016 | Audio Players & Recorders
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Honeywell digital thermostat went blank, ac unit wont come on, its an 8400c, no breakers tripped
This thermostat has batteries. Try replacing the batteries. You may have to reprogram and make sure it is on.
Jul 18, 2010 | Honeywell Programmable Thermostat Heater
The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
May 10, 2010 | Honeywell Programmable Thermostat Heater
My screen went blank on my thermostat. How can I get it back on?
Normally the digital thermostat required a power source to function, please check the connect at the c- terminal if your thermostat is hardwired.
You can call this number for technical support 18002842925
Apr 25, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Carrier thermidistat screen went blank
Check the battery in the thermostat it is dead!! Should be 2 AA batterys!
Sep 11, 2009 | Carrier Heating & Cooling
My screen went blank. When I power up, the SANSA
Press menu button for 15 then it turns off .. after that .. turn it on again
Jul 12, 2009 | SanDisk Sansa e260 MP3 Player
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
LCD screen blank
not a user serviceable problem
send for repair
Dec 19, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Heating & Cooling Logo
422 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
